Winter is coming and some places even already have snow, so lets see those winter setups!
Currently still waiting for Black Friday to buy wheels and tires, so I hope it doesn't snow too much in the meantime.
Currently debating on x-ice or Blizzaks and wheels. What's the minimum size to clear the bigger brakes on the F-Sports?
Hopefully my MXM4s and AWD can handle the snow until I get some proper tires.
They will, just be VERY CAREFUL with your speed and stopping. You probably won't get stuck, but don't depend on them for much
stopping bite. I drove an entire winter with mine just fine.
If you have F-sport AWD you don't have bigger brakes. Our brakes are the same size as the Base GS.
Whatever you do beef up the profile/sidewall of the tire, don't be running P235s.... If you hit potholes with the stock OEM rim/tire setup at any decent speed you WILL BEND the rims. I bent 3 out of 4 over one winter. I decided to keep mine off the road most of this winter instead of go through that BS again.
I’m getting my underbody coated in a anti-corrosion spray this season, the brine salt can do a real number on your components. But other than that I run DWS-06’s which perform awesome in the lake effect snow Cleveland gets.
Are you removing all the plastic panels from underneath the car? Pretty much the entire underside is covered. I think with the under protection this car already has, it would be a waste of time and money.
17" won't clear your big brakes if you have the F-sport model, but if you have the non-f-sport, they should be good!
I was informed earlier in this thread that the AWD F-Sport models don't have the big brakes? I thought they had 14" brakes too, or is 14" the normal size brakes?
Thats correct - AWD F Sport models do NOT have the larger brakes/rotors. Base model GS's up to premium package, lux and AWD F-Sports all share the same brake size.
This is from the lexus brochure: GS350 F Sport AWD: 13.1-in ventilated front discs with two-piston calipers, 12.2-in ventilated rear discs with single-piston-sliding calipers
GS350 F Sport RWD: Four-piston front calipers with 14.0-in ventilated rotors, pin-mounted to an aluminum hat; 12.2-in ventilated rear discs with single-piston-sliding calipers
Here is an image of a GS I took that pulled up next to me a few years back with OEM Lexus 17" wheels offered on base model GS's:
Any problems with rubbing? You have an AWD model, so it sits a bit higher, right?
No rubbing at all with AWD, but I'd say this is about the maximum diameter you can run. With the wheel turned about half lock, the inner edge of the tire just barely clears the front of the wheel well by less than 1cm.
The 225/45 increases diameter from stock about half an inch.
I have a can of Chassis Saver sitting for the past few months. Been too lazy to get under the car and scrape off the existing rust and spray this on... maybe after New Years...
I have a set of 19" Michelin X-Ice XI3 on Niche Misano wheels that should work well for current GSs. They're off my RCF so caliper clearance definitely won't be an issue. In as-new condition - PM me for info.
Consider your TPMS sensors cloned if getting a second set of wheels. This way you do not need to deal with reprogramming TPMS IDs each time the wheels are charged.
