How to replace headlight bulb?
Old May 10, 2018 | 08:01 AM
RAMBLER2's Avatar
RAMBLER2
Question How to replace headlight bulb?
Can anyone direct me to a DIY tutorial on replacing the headlight bulb on my 2015 GS 350 F sport?I can find for other years and models.Yes it is covered under warranty but dealer has over 2 weeks wait time,I would like to do it myself if practical.
Old May 10, 2018 | 08:16 AM
jtrue28's Avatar
jtrue28
Which side of the vehicle?
The driver's side is a PITA. Passenger side is pretty straight forward.
Trying to jog my memory.... There should be a ballast attached to the back of the housing. That should screw off. There will be a cable attached to the bulb from that. Disconnect that. There will be a clip that you need to squeeze and remove. It is hinged, so once you release it from the bulb, it will be hanging from the other side. Turn the bulb, keeping and eye how it is notched and where the notches go, so that re-installing the new bulb will be easier. Do NOT touch the bulb glass. Use nitrite gloves if you have them. Follow the steps in reverse order.
If you need to replace the driver side, you may have to come through the wheel well. Turn your wheels all the way to the passenger side. There will be a panel that you can remove with a screwdriver.
Old May 10, 2018 | 08:48 AM
RAMBLER2's Avatar
RAMBLER2
Ok thanks,it is the passenger side.so it can be reached from the top?how do i remove the round fasteners that hold the platic cover in the engine bay?Ok I have got the cover off.Pretty tight in there.
Old May 10, 2018 | 11:29 AM
RAMBLER2's Avatar
RAMBLER2
Ok have the bulb out.Local store will get one by tomorrow $150 + tax.Ouch!
Old May 10, 2018 | 12:19 PM
er34's Avatar
er34
Check your PM
Old May 10, 2018 | 12:52 PM
np20412's Avatar
np20412
the bulbs are not cheap. if you buy one I would take it up with Lexus to reimburse you for the cost under warranty as the car is not legally operable with a failed headlight which would otherwise be covered under warranty.
Old May 11, 2018 | 11:07 AM
jtrue28's Avatar
jtrue28
Yeah, passenger side is tight, but driver side is awful because of the wiper fluid reservoir.
You get D4S bulb? I actually have both of my original bulbs from my 2013. The thing is, I don't think I ever used them. Swapped them out the first day I had my 2013 for the Philips Ultinon 6K bulbs. They've been sitting in the Ultinon box for the last 6 years. I'm sure they still work. I have the LED headlights on my 16 now, so they're of no use to me.
You'll need to push the outside of those fasteners back down, before putting everything back together. When you put the fastener back in, don't push down too far, then you'll have to do it all over again. Just the right amount of pressure until the button is flush.
Old May 11, 2018 | 05:01 PM
RAMBLER2's Avatar
RAMBLER2
Yes i got the DS4,other stores around here wanted $190!.What are Phillips Ultinos?They last longer?I'll check the fasteners thanks,they seemed pretty loose whe i put it back together.
Old May 11, 2018 | 05:09 PM
RAMBLER2's Avatar
RAMBLER2
Yes I was dissapointed in their response,they did say to try them each afternoon in case they could fit me in but i need to use the car.
Old May 12, 2018 | 08:30 AM
RAMBLER2's Avatar
RAMBLER2
Pictures that may help someone.
Old May 12, 2018 | 01:48 PM
jtrue28's Avatar
jtrue28
Ultinons are 6k. Won’t necessarily last longer, just a more white/blue color than the stock 4300 bulbs.
cvuplay
RX - 3rd Gen (2010-2015)
12
Feb 24, 2016 10:04 PM
lserlohn
RX - 1st Gen (1999-2003)
Nov 11, 2011 06:25 PM
jagalchi88
Sep 19, 2011 09:17 AM
TORTOISE
Jan 5, 2009 11:10 PM
