2014 lexus gs fsport help!!!
hey im trying to change the OME turn signal bulbs to a LED bulbs. I bought some 7440 LED no resistor required bulbs off of ebay and im still getting a hyper flash. Does anyone knows what LED bulb i have to get or where to get tham from to have a normal flash? Thank you
Trying to put LEDs in place of a standard bulb that flashes causes the hyper-flash because of change in resistance. You'll need something that comes with a load resistor that will "fool" your factory ECU or the electrical system to think the load is still the same with the low-draw LEDs you're tryin' to use. No solution will be fully plug and play bc you'll still need to mount the resistors/ground them to any metal part of the frame...Did your eBay bulbs come with resistors?
iJDMToy makes some pretty good stuff. You might need to try something like these that they make with the load resistors built in: https://store.ijdmtoy.com/No-Hyper-F...s-p/20-001.htm
No they didnt, theye were suppose to be resistor free no hyper flashing LED bulbs. I dont want to mount the resistors in bc my car is still under waranty. So there is no LED bulbs with built in resistors?
guccigucci
GX - 1st Gen (2003-2009)
Feb 26, 2018 08:20 AM
CAN-Toronto Cree Q5 LED turn signal bulbs 7440
RudeDoggy
General Classifieds
Jul 10, 2013 06:06 AM
