HUD Retrofit
Old Aug 2, 2019 | 10:52 AM
  #136
thallium's Avatar
thallium
I'd like to do this but I have some questions:
  • Is the HUD visible with polarized glasses?
  • Does an astigmatism make the HUD fuzzy?
  • How does it look without the proper windshield?
I just got my windshield replaced and if I had been considering this I would have gotten the HUD version instead.
Old Aug 2, 2019 | 12:31 PM
  #137
bclexus's Avatar
bclexus
Originally Posted by Dotslash
Not a lot to ask at all! I plan on updating that post with full instructions and pictures.
That sounds like quite a task!
I could see it requiring many dozens of pictures and literally thousands of words to detail the full instructions to follow.
Old Aug 2, 2019 | 01:04 PM
  #138
gordonyz's Avatar
gordonyz
  • yes and barely
  • dont have but don't think it will if windshield is the one for HUD
  • there will be double edges.
to me HUD is OK I just display speed numbers.
the tac line is so thin its like trying to spot a nail on the toad, not worth showing.
Old Aug 15, 2019 | 03:24 PM
  #139
Dotslash's Avatar
Dotslash
Just a warning to anyone looking to do this; Make sure your car has the harness installed that's for the HUD switch. Otherwise you cannot do this.
I purchased all the parts without checking and now I'm stuck with a $100 HUD Brand new Switch.
FYI I've got a 2018 GS350 F-AWD
Old Aug 16, 2019 | 11:21 AM
  #140
jonathancl's Avatar
jonathancl
Does that mean you must abandon this project?
Old Aug 16, 2019 | 03:12 PM
  #141
eddie420's Avatar
eddie420
It is definitely there, it's plugged into a fake switch. You have to remove it from that and plug in your switch. The first time I did it, I thought the same thing.
Old Aug 16, 2019 | 06:38 PM
  #142
baconRx's Avatar
baconRx
hopefully they'll come out with a 24" HUD for the next gen GS unless someone wants to try retrofitting the LS HUD into our car =)
Old Aug 16, 2019 | 10:44 PM
  #143
Dotslash's Avatar
Dotslash
I don't think it is. I have the switch in front of me as well as my dash apart. I took all dumb switches apart - It's not there.
Old Aug 17, 2019 | 03:35 PM
  #144
eddie420's Avatar
eddie420
Can you take a picture of the left side of the console (to the left of the steering wheel)? Just a couple of shots of the wiring.
Old Aug 17, 2019 | 03:49 PM
  #145
Dotslash's Avatar
Dotslash
All those capped blues / greys are too wide. The switch is a smaller plug.
Old Aug 17, 2019 | 04:23 PM
  #146
eddie420's Avatar
eddie420
The small top one is the odometer one and the bottom one is the HUD one and both are clip type. I will check TIS.
Old Aug 17, 2019 | 04:27 PM
  #147
eddie420's Avatar
eddie420
The 2016-2018 GS350 FSport has the harness in the same location as the 2013-2015 (highlighted pink).
EDIT: Same connector too.
EDIT #2: Follow the cable from your left air vent. See if you can find it using that.
Old Aug 17, 2019 | 04:31 PM
  #148
Dotslash's Avatar
Dotslash
No joy. I've tried to connect the switch to every dead capped connector in the car with no luck.
Old Aug 17, 2019 | 07:33 PM
  #149
eddie420's Avatar
eddie420
Yikes... @peasodos Any other suggestions? I'll be surprised if they actually got rid of the entire harness assembly.
Old Aug 17, 2019 | 10:41 PM
  #150
peasodos's Avatar
peasodos
I think it's got to be there. I didn't want to take apart my switch to take a pic of the actual plug. Unless Lexus removed the HUD option in 2018(which they didn't) it should be there.
