Snow tire chains
Old Jan 2, 2017 | 08:38 PM
Tom4GS's Avatar
Tom4GS
Default Snow tire chains
Can someone please recommend a set of snow tire CHAINS (per the manual, cables are now allowed). Search results didn't return much.
I own a 2015 RWD, tire size are P235/45R18. I live in SoCal and would like to hit the mountain roads for some snowboarding and want to have the chains with me in case they are needed/required by CHP.
No luck on Amazon / Autozone / etc.
Thanks in advance.
Old Jan 3, 2017 | 09:03 AM
ULTiMaX99's Avatar
ULTiMaX99
https://www.walmart.com/ip/Peerless-...ables/19853276
These are cables, but I used this exact size last year on my IS250 255/40/18 while going up to Bear. They worked perfectly fine. I picked them at the Highland Walmart right when you exit the 210 to head up to Bear.
Old Jan 3, 2017 | 09:08 AM
shurik74's Avatar
shurik74
I used pretty much the same as above years ago on FWD, easy to put on and take off but make sure they tight good, otherwise you might damage rear quarter panel if they come loose. I recommend to drive less then mile after you put them on then tight them again...
Old Jan 3, 2017 | 03:11 PM
Nimimi's Avatar
Nimimi
I use Autosock as it's sold by the Lexus dealers in Western Washington. It is approved by the state to use when chains are required.
I can't comment on their use, however, as I've never used them since I have an AWD.
cobovn
Feb 5, 2019 06:52 PM
vi3tbwoi
Sep 25, 2018 07:54 PM
ChronoJ1
Wheels, Tires & Brakes Forum
Nov 30, 2007 04:21 PM
