Loud engine / vibrating noise while in idle?
Old Apr 26, 2016 | 08:18 AM
AJLex19's Avatar
AJLex19
If its something that bothers you and you have good experience with the Lexus brand, I agree with other posters that you should take it in for service. My personal mechanic told me certain things that led me to take my car in to Lexus.
I took it in and drove with a Lexus tech - they didn't "hear" the grinding noise and could not "reproduce" the problem with a noise with the transfer case. Here's why it was important to take the time to take it in:
Its easier to make an argument for a warranty fix if the dealers is difficult in the future because there is a history on the car when properly documented by the tech.
Once I took it in and it was all documented, I felt more comfortable because if it turned out to be a bigger issue in the future, I could take it in and they could see that I came in based on any of the previous "warning signs."
Bottom line: I would def. take it in to not only ensure there is not a problem with my car but also to just clear my own head.
Old Apr 26, 2016 | 08:32 AM
ashleymari's Avatar
ashleymari
I agree. I've heard the GS is louder than the ES (my previous car) so I wanted to make sure that it wasn't just normal noise. You all have pretty much confirmed that it isn't, so I'm going to try to make it to the dealer tonight before the service department closes. Thanks!
Old Apr 26, 2016 | 09:27 AM
bclexus's Avatar
bclexus
Just in case you are not aware - the GS 350 has direct fuel injectors that make a significant clicking noise every time they squirt fuel that can be easily heard at idle and low RPM. Many people that are not familiar with this sound of direct injectors think something may be wrong with their engine. Many newer cars have direct fuel injectors nowadays...
Old Apr 26, 2016 | 10:37 AM
ashleymari's Avatar
ashleymari
It's not a clicking noise and it doesn't sound like it's coming from the engine area. It's a low, dull vibration, that is very irritating to the ears. You can't hear it while inside the car, only on the outside or when the windows are down. When I try to isolate the sound in a closed area (like my garage), I'll hop out of the car and it sounds like it's coming from the mid-back section of the driver's side of the car.
Old Apr 26, 2016 | 11:56 AM
bclexus's Avatar
bclexus
Maybe the fuel pump or the evaporative emissions fuel vapor canister system.
Old Apr 27, 2016 | 02:52 PM
lamikela1's Avatar
lamikela1
Originally Posted by ashleymari
My '09 ES you could hear a pin drop when in idle. Such a quiet car!
That's my worry...to head all the way to the dealership for them to tell me the sound is "normal". Was the buzzing sound in your '13 more of a vibration coming from the exterior of the car? I cannot hear or feel it while I'm in the car itself with the windows up..BUT if I am sitting idle with the windows down, it's very noticeable. It's not incredibly loud, but the dull vibration sounds actually hurts your ears.
Mine was not a vibration that I could feel in the steering wheel or by touching the car. It was more like a buzz that could be heard throughout the cabin. It's hard to explain but was very annoying especially after coming from a very quiet '08. It was almost like a sound that's coming through the speakers in the sound system. All I had to do was to step on the accelerator slightly and it would stop and would be very smooth until I let it go back to idle.
Old Jun 26, 2016 | 04:41 PM
Fcdrifter2's Avatar
Fcdrifter2
With a/c on full blast 750-800
Old Jul 6, 2016 | 09:08 AM
peteharvey's Avatar
peteharvey
My 4GS idles louder than previous Lexus models, and you can hear the details more too.
However, the idle noise is not the problem.
The problem is that with more and more miles, it is idling more roughly, to the point where there is a little resonance in the dashboard in D with the foot on the brake pedal.
According to the dealer, it is part of the bigger 3.5L capacity, and nothing can be done.
Likewise, the 3.5 doesn't rev as sweetly as their old 3.0 V6's from 1996-2006 either.
This is a good reason for Lexus to move into a smaller 3.0 V6 with forced induction - not just the power and economy, but also brings back the refinement...
Old Jul 6, 2016 | 10:21 AM
Dallasguy1's Avatar
Dallasguy1
I currently have the 2IS and had the 3GS in the past but this one is definitely louder then both that once I had to joke that Lexus have put Diesel engine in this one.
Old Jul 11, 2016 | 06:45 AM
DallasDave's Avatar
DallasDave
I just purchased a 2015 GS and notice a ticking noise when sitting still (transmission in D). I'm surprised to hear that's it's normal, but will probably have it checked out when I return to the Dealership to pick up my license plates.
ashleymari - good luck with your problem, as it sounds like it might be a little different than what I am describing. Can you get a short recording and upload it for us all to listen to?
Old Jul 11, 2016 | 10:22 PM
mrpink13's Avatar
mrpink13
one f sport i checked out had a noticeably loud idle....the guy said he did oil changes himself and was a 'car guy' that worked and cared about his cars. but i knew while that is true what also comes with that is being an enthusiast and i know he drove the cr@p out of that car....
Dreamcast
Jul 20, 2017 12:32 PM
sdloeffler
Jun 14, 2016 03:01 PM
jvjr9902
Jul 1, 2013 09:02 PM
rembo
Nov 6, 2008 02:31 PM
jbrinkley
Dec 29, 2007 12:24 AM
