Moist smell in AC
In order to gain "credits" against the coming CAFE fuel efficiency/emission standards, Lexus has reprogrammed its AC systems. Where they used to be biased toward fresh air intake, they are now biased toward recirculated air. This change allows Lexus to put off (for a short while) the really tough engineering compromises required for compliance with the truly gruesome post-2016 CAFE standards. And, best of all, it only comes at the expense of the comfort and wallets of loyal Lexus customers! What could be better?
I've had three other Lexus's and NONE had a problem with mildew smells, neither did my older Camry, or my Accord. Taking this out to my immediate family, we are looking at roughly 18 cars in the last 20 years and this is the first that has a problem. So it's not as common as many of you like to claim.
Now it's obviously occurred with many of you before your GS, but you're in the very small minority. Obviously something is different with the 4th gen GS that causes it to have the mildew problems much more frequently than other cars. Finally just to drive home this point, my Lexus dealer told me tonight that there are only a couple of models that have ever had mildew smells, but she couldn't remember which others.
I think it's just a design flaw, on all these different cars, with the AC design. Somewhere, water is puddling and not evaporating. Infiniti used to advise people to run fresh air instead of recycled air for the last 5 minutes before parking it (in an effort to dry out condensation I believe) but that only works if the outside air isn't swampy. Here in north Texas, it's swampy frequently thanks to southerly winds from the Gulf. So that option doesn't work for us.
Whatever the case may be, I know for a fact that alot of cars don't do this, and 80's and 90's cars didn't have this problem either. At some point a fundamental engineering change was made that caused this to happen. I'd love to know what it was, why it continues, and why it's not the focus of a major redesign. Google is full of results for this, and KBB even has an article on it at http://www.kbb.com/car-advice/articl...ide-car-vents/.
Just for the record, I've read this whole thread and my beef with my GS after almost 3 years is that when in Auto mode it NEVER moves from Recirc to Fresh. I have just gotten used to doing it manually after I've driven for a few minutes. (And I've done the smog adjustments mentioned in the earlier post.) I think I read somewhere in this forum that it will not move out of Recirc mode until the outside temp is 75. When the temp gets that low I just turn the AC off and use fresh air.
Mine has no moldy smell, so perhaps there really is something to be said for driving with the AC in a mix of fresh and recirculated air. I did have an Infiniti M35 that had horrible smells coming from the vents when the air was first turned on, so this is not isolated to Lexus. Also, at home when I turn my AC on for the first time after having the heat running it smells.
I think the logic is that with outside air at, say, 88F and cabin temp initially at, say, 110F, recirc will set up a (psuedo-)positive feedback loop where the intake air is continually cooler. Once the cabin temp cools to 88F, recirc becomes much more efficient at keeping the setpoint of, say, 72F. This is because fresh air intake would require continuous cooling from 88F to 72F whereas recirc would only require cooling from the cabin actual temp to the setpoint. Surely you see that the initial SHORT-TERM inefficiency of recirc (high cabin to setpoint) is more than offset by the LONG-TERM efficiency of recirc (near-setpoint cabin to setpoint) compared to the initial benefit of fresh (ambient to setpoint) versus its long-term inefficiency (same ambient to setpoint). Consider the amount of time the car typically operates in each mode. THAT should give you the sense of why recirc is favored over fresh air intake for increased fuel efficiency and reduced emissions.
http://www.epa.gov/otaq/climate/documents/420f12051.pdf
and same heading on Page 62628 (yes, page 62,628!) in Federal Register:
http://www.nhtsa.gov/staticfiles/rul...Final_Rule.pdf
and under "Air Conditioning Improvements" at bottom of document:
http://www.c2es.org/federal/executive/vehicle-standards
Does the Lexus defaulting to recirculate above 75 degrees make it more likely than running fresh air all the time? Probably. But, thats not a "feature" unique to Lexus...its something all carmakers are going to...our 2014 Jeep does the same thing. You have control...just select fresh air. Its annoying to do it every time, sure. But...blame congress not carmakers.
Like I said, my GS had this moldy smell when new. They cleaned the HVAC system under warranty...it was gone for about 25,000 miles. This summer it came back. I bought a $7 can of cleaner at PepBoys and emptied it into the vents...its just as gone as after the dealer's HVAC cleaning. Our new Jeep developed the same smell this summer...emptied another $7 can into it...it smells great.
So...if a $7 can of cleaner and 5 minutes of time when washing the car to empty a can into the system and let it run for 10 minutes while you dry it off is them "giving it to Lexus owners in their wallets"...I think we all need a little perspective.
To me it is a non-issue. Honestly...the can worked so well it wasn't worth the energy to even tell the guy at the dealer when it was in for its next service even if they would have done it again for free.
