Removing SiriusXM stations
Old Nov 9, 2023 | 09:55 AM
MJA1951's Avatar
MJA1951
Default Removing SiriusXM stations
Sirius XM just changed what was formerly channel 27 to channel 308. Unfortunately the 2013 GS radio doesn't go up that high. Siriux XM automatically changes the radio to look for station 308, which isn't available.
Every time I scroll thru the presets, once I get to what shows as 27, but to the radio is looking for 308, I get a channel Unavailable message and it goes back to channel 26 or channel 1.
Anyone know how I could delete channel 27\308? If not how can I delete all the XM stations without resetting everything (nav\phone, etc). This would be more work but then I can manually reenter all of the stations
Old Nov 9, 2023 | 10:50 AM
charley95's Avatar
charley95
I could've sworn my regular channel was 74 until it changed to 75, sucks getting older.
Old Nov 13, 2023 | 07:30 AM
NJLEXES's Avatar
NJLEXES
At least on my 2017 which should be similar in that regard, there is no way to actually "delete" a preset channel you have programmed.
You only store a different station into that same preset.
Old Nov 13, 2023 | 07:51 AM
bclexus's Avatar
bclexus
I think that's correct. You replace the preset station you no longer want by overwriting it with a new one.
There is a problem however with many radios only being able to receive SiriusXM channels up to 200 or so, yet some of the SiriusXM channels go much higher in number, above 300 making their radios unable to select or save to memory the higher numbered channels. The 'streaming only channels go from 700 up through 900 I think. I don't know what the answer is for that...
Old Nov 14, 2023 | 08:30 AM
NJLEXES's Avatar
NJLEXES
Right.... my 17 GS350 only goes up into the 200's.
However my wife's 2020 NX300 goes up into the 300's channels.
Old Nov 4, 2024 | 08:04 AM
mcomer's Avatar
mcomer
Use the SiriusXM App and play it through either Bluetooth or an AUX cable.
App has better fidelity than the Satellite down link. If BT connected it will also
respond to Siri commands, press and hold the "talk" button on the steering wheel:
"Please tune the SiriusXM App to play Bluesville".
RGSW
RX - 4th Gen (2016-2022)
Mar 22, 2017 09:53 AM
bootman
Jan 9, 2017 03:52 PM
DTBOSS
Mar 6, 2015 08:22 PM
jambo1
Jun 22, 2006 05:21 AM
