How to upgrade headlights to the 3-projector version
Old Mar 9, 2023 | 09:37 PM
AightDen13's Avatar
AightDen13
2nd gear
So tired of looking at my 13’s yellowed and foggy headlights. I’ve had lexus refinishes them so many times, they gave me my money back. Even pulled them out and did a thorough refinishing only to have them last 6 months, if that. The poor light output is making it unsafe to drive for my wife.
These triple beams look sharp. So are they plug and play on a 13 f-sport? No programming/coding needed?
Old Mar 10, 2023 | 02:24 AM
PGA71's Avatar
PGA71
They are suppose to be plug and play according to some of the posters here.
Same as you, on my 13, they were very yellow and hazy and was considering upgrading the headlights.
But gave the 3M HL Restoration Kit, Heavy Duty 2-Pack and Meguiar’s G17804 Keep Clear Headlight Coating a shot which I purchased off Amazon. (Both links below)
Amazon Amazon
Amazon Amazon
It removed all the haze and anything else that was on there because of the elements over the years.
Watched a couple of youtubes that gave me confidence that I had all the tools I needed to do the job right.
Had to buy automotive masking tape to cover around the lenses to protect the paint and used my cordless drill.
Only had to use one of the packages in the 3M 2-Pack, but wanted the extras in case I needed to redo or needed more sandpaper or compound because of the amount of haze that was there.
Then sprayed 2 coats of Meguier’s headlight clear coat about 15 minutes apart which I think was the key. This step makes the headlights look amazing and provides protection so that the haze / yellowing does not return.
Entire process took about 90 minutes including cleanup.
Give it a shot if you want to keep the stock look.
Old Mar 10, 2023 | 07:51 AM
AJLex19's Avatar
AJLex19
Lot's of owners had shops install PPF like Xpel to their headlights with success. Even if you buy brand new headlamps, they'll become hazy after a year or two. I think the only way to stop the hazing and yellowing is to have affected headlights restored and then have PPF or ceramic coating installed:
https://www.clublexus.com/forums/gs-...eadlights.html
https://www.clublexus.com/forums/gs-...tion-film.html
For me, i've done the more laborious route of a once a year process: using Maguire's Headlamp Restoration kit.
Old Mar 10, 2023 | 08:39 AM
kietlander's Avatar
kietlander
Originally Posted by jgscott
Get a Quote for the shipping cost to you.
$120 for shipping including
Club Lexus Editor
Lighting
Aug 31, 2017 07:32 PM
Sleam
May 16, 2010 02:47 PM
Nosexnolex
Dec 3, 2007 05:42 AM
mdnt_7
Automotive Care & Detailing
Dec 2, 2003 08:37 PM
