Control module code
Old Nov 28, 2021 | 10:52 AM
acwebb's Avatar
acwebb
Exclamation Control module code
My car is showing control module $7E8 and $7E9 CAn anyone tell me what my problem is or is it an expensive fix? I have 2008 GS350
thanks for any help you can give me.
Old Nov 28, 2021 | 11:13 AM
CruzinGS's Avatar
CruzinGS
Probably worth checking with your scanner's instruction manual, but my random googling suggested that those are possibly sub-menus, and you may have codes stored for control module $7E8, which is the engine PCM, and $7E9 which is the transmission PCM. Or there may not be codes for either module. Can you try selecting each module and clicking the "Go" or similar button?
Also, are there any specific symptoms you are trying to diagnose? Is the "Check Engine" / "Malfunction Indicator Lamp" on?
Old Nov 29, 2021 | 01:40 AM
ibidu1's Avatar
ibidu1
If your codes got dollar signs $ then surely it is expensive to repair
As cruzin suggested read your scanners owners manual as those are not lexus/toyota codes. Drive it to your closes auto parts store and see if they will let you use their scanner.
bobby9063
LX - 3rd Gen (2008-2021)
Jun 14, 2021 07:28 AM
roachman
May 23, 2011 07:03 PM
Wags
13
Feb 4, 2010 06:06 PM
shahir18
Sep 26, 2006 05:19 PM
