Brake job
Old Aug 6, 2021 | 08:19 PM
Countryguy's Avatar
Countryguy
Default Brake job
This might be a dumb question. Everything I've read shows bleeding the brakes and removing the brake bleed line when replacing brakes on a gs350.
On my other cars I've always just used a clamp to push the pistons back flush in the caliper.
are you not able to do that with a gs350 or is bleeding the brakes required every time you do a brake job?
Old Aug 7, 2021 | 12:32 PM
ibidu1's Avatar
ibidu1
You can push in the pistons into the brake caliper normally, just like any other car. The issue is when you decide to bleed the brakes, the abs system will not allow you to fully bleed the system. You will need a techstream and through the options open the abs valve. Or take it to the dealer.
What I did, I swapped out the pads with out bleeding the lines. But I emptied the brake fluid in the reservoir using a turkey baster, I just vacuumed the old brake fluid, and poured in new fluid. After time the old fluid mixes with the new, and well its best to do this method atleast 2 times. It doesnt take long, and super fast
Old Aug 9, 2021 | 08:56 PM
GeeYes300's Avatar
GeeYes300
I believe you need to unscrew the cap on the brake reservoir before you clamp the pistons back flush.
dmanwi
Mar 2, 2020 11:01 AM
UtoyZ
NX - 1st Gen (2015-2021)
Feb 16, 2016 10:52 PM
JASP615
GX - 1st Gen (2003-2009)
Jul 7, 2011 09:43 AM
S to the K
Suspension and Brakes
May 23, 2008 08:47 PM
Lexs400
Jul 8, 2005 02:29 PM
