Power issues urgent help
Old Oct 23, 2020 | 09:21 AM
MIKEY1992H's Avatar
MIKEY1992H
Question Power issues urgent help
My 2007 Lexus GS450H broke down the other day and wouldn't start, got it recovered to my work (Toyota dealership) techs had to push it into workshop. It wouldn't crank over only the MG motor was making noise, had error codes P3190 - P3190 also computer read bank 1 & 2 running lean.
Thought it might be high pressure fuel pump, but changed that and have managed to get it it started and driving, however when speeding up I can feel the power holding back at 60 - 70mph and not able to push it faster!
was hoping someone could shed some light on this?
Old Oct 23, 2020 | 11:39 AM
PauloFR's Avatar
PauloFR
Maybe this is the low-pressure fuel pump in the tank that is going out or has a clogged filter? I don't know if it is possible but you should have its pressure checked.
Old Oct 24, 2020 | 01:56 AM
ibidu1's Avatar
ibidu1
I dont know much about hybrids, but if the cars regular engine is not cranking over then its most likely not a fuel issue. But more of an electrical issue. It could be low voltage to the battery, did you try jump starting it with another vehicle? It could be bad terminals, key fob, or the starter.
Old Oct 25, 2020 | 06:53 AM
PauloFR's Avatar
PauloFR
If I understood correctly, the car now starts but loses power when going over 60 mph (I replied accordingly)
RRRacing
IS F (2008-2014)
Oct 23, 2020 02:13 PM
Robinson11
Maintenance
Jan 3, 2020 02:33 AM
LexusDude9
Maintenance
May 15, 2019 06:27 AM
nowUZme2
Apr 24, 2018 10:55 AM
bucsfan200
Jan 19, 2008 08:55 PM
