Plastic Evap Line Fix
Old Jan 1, 2020 | 07:20 AM
2008GS's Avatar
2008GS
Default Plastic Evap Line Fix
Dealer says complete fuel tank needed since plastic hoses are bonded to the tank. Quote $1800! The fuel tank evap line has been chewed by rodents and is leaking. You guys have provided inventive solutions in the past. Please review pic. My idea is to cut section of bad conduit and insert smaller diameter hard rubber tubing into existing plastic conduit. I plan to secure it with small hose clamps. My worry is whether it will seal and prevent CEL. Any suggestions or other ideas?
Old Jan 1, 2020 | 11:43 AM
ibidu1's Avatar
ibidu1
You can do that or you can buy a used fuel tank off your like junkyard for 50 bucks. Or just ask them if you can just buy that hose.
Old Jan 1, 2020 | 01:57 PM
2008GS's Avatar
2008GS
Cannot buy replacement hoses, they are bonded to top of tank. Used tank might be an option except 6hr replacement labor.
Old Jan 1, 2020 | 02:24 PM
ibidu1's Avatar
ibidu1
lol that sucks! Try this, cut the flex hose portion all the way to the end to where it is just round with a nice sharp razor blade so that you dont crush the roundness off it. Then measure the outside diameter of those round end and at your local auto parts store purchase fuel line with the inside diameter of the end you just measured. Also its a good idea to purchase different sizes as small sections of fuel hose is cheap. Then you can either slip the hose right over, and use a small zip tie to hold it tight. Or you can use a rubber cement to help glue the line on but the zip tie should hold just fine.
Old Jan 1, 2020 | 02:32 PM
2008GS's Avatar
2008GS
Now that's what I was considering, just hope it doesnt leak. If it does, at least I attempted to save cost of new tank and labor.
Old Jan 1, 2020 | 02:50 PM
ibidu1's Avatar
ibidu1
Such a silly design, goodluck and let us know the outcome
Old Jan 2, 2020 | 07:30 AM
TRD_Power's Avatar
TRD_Power
This would be my suggestion. You can also throw on some heat shrink tubing around it to add an extra layer of assurance. I know there are several out there that will hold up just fine on this.
Codfish
Jul 15, 2018 11:52 PM
akafixture
Jun 25, 2016 04:10 PM
hfsdude007
Feb 7, 2013 06:12 AM
MooJohn
Apr 19, 2012 04:07 PM
