GS350 Immobilizer/ECU Issues
Old Dec 30, 2019 | 11:03 PM
lexdallas's Avatar
lexdallas
Default GS350 Immobilizer/ECU Issues
Hello everyone I really need help on this please... 2009 GS350
I reset (via techstream) my car immobilizer due to all key lost situation... All reset process was perfect but at the moment to register a new smart key code fob, I had a car battery issue and was not able to add that key. I disconnected the battery to recharge and then I put it back later to continue the process, but this time the dash is not coming on, when I push the start button nothing happens, only the door light is on on the dash but nothing else. I attempted to reset the immobilizer again but keeps failing after reset code is entered. The security light keeps flashing all the time... I disconnected all horns. No idea what else to do in this case... I have been searching online but nothing to solve this issue. Thanks for your help!
Old Dec 31, 2019 | 03:50 AM
ibidu1's Avatar
ibidu1
I wish I can help you but I dont have experience with techstream and keying process. You can call a mobile key shop in your area, they usually can reprogram it for you, depending if the new key fobs part numbers are correct for your car. Im assuming it would be a lot cheaper then towing it to the dealer.
Old Dec 31, 2019 | 05:40 AM
sha4000's Avatar
sha4000
Take it to the dealer. If the battery dies while your doing anything in techstream you can brick your ECU. Don't mess around just pay the money to correct your mistake.
Toyboy250
Mar 11, 2024 01:06 AM
lexdallas
Dec 24, 2019 12:45 AM
dickeyje
Dec 8, 2013 02:30 PM
gstois
Nov 14, 2005 03:45 AM
