Tires
Old Apr 1, 2019 | 01:15 AM
amy8350250's Avatar
amy8350250
Default Tires
I just bought a 2008 ES 350. The tires say they are tubeless. I think the previous owner took it back to Lexus and got new tires when they were due. I was just wondering how to maintain tubeless tires. Apparently you don’t put air in them!
Old Apr 1, 2019 | 06:30 AM
MX73's Avatar
MX73
All modern tires are tubeless and you put air in them. Maintenance is just like any tires. Check the PSI, make sure there are no cracks, bubbles, exposed steel belts, check for abnormal tire wear and carry on.
Old Apr 1, 2019 | 07:19 AM
tghw's Avatar
tghw
First, this is the 3G GS forum. You should post any questions about your ES in the appropriate ES sub forum for best responses.
See MX73's post above regarding proper care of your tubeless tires. Are you possibly confusing the term "tubeless" with "run flat"? Regardless, run flat tires are also tubeless and maintained the same as non-run flat tires.
caseycat89
32
Jan 31, 2024 12:44 AM
ilexusown
31
Aug 20, 2016 06:43 PM
mlacomb
Dec 2, 2011 04:25 PM
gandro
Jan 29, 2008 01:36 PM
jhp012
Jan 20, 2008 10:10 AM
