Seafoam
Old Apr 28, 2018 | 11:35 AM
phenomenon's Avatar
phenomenon
Default Seafoam
I'm looking to give this seafoam thing a try before looking to turn in my car to Lexus for upper intake cleaning.. and not quite sure where thee vacuum line is for the brake booster.
anyone got a quick snap picture of which one is it. Before posting this I did the google and YouTube but it was giving me mix signals.. thanks in advance boys/ girls
Old Apr 28, 2018 | 02:26 PM
ibidu1's Avatar
ibidu1
On my GS350 I popped off the engine cover, and there was a blank plugged up vaccum line near the fire wall. I simply removed the clamp and slid off the plug and found a vacuum line that matches the nipple.
Old May 1, 2018 | 03:48 AM
Broncosi's Avatar
Broncosi
Are there multiple uses for Seafoam? I was under the impression you put a bottle in your gas tank (1oz to 1 gallon).
Old May 1, 2018 | 06:42 AM
MX73's Avatar
MX73
There are multiple uses for seafoam. You can pour a small amount in the cylinder, pour is slowly through a vacuum line, pour it in the tank, and/or pour it in the crankcase.
Old May 1, 2018 | 08:15 AM
Viru's Avatar
Viru
A very important distinction - there are 2 distinct Seafoam products that aren't often acknowledged as such.
Seafoam Motor Treatment (https://seafoamsales.com/sea-foam-motor-treatment/): for pouring into oil or fuel
Seafoam Spray Cleaner & Lube (https://seafoamsales.com/sea-foam-spray/): for spraying just before the throttle plate
It is not recommended to try sucking the Motor Treatment directly into the combustion chamber as that's not the application it's designed for. Can you get by doing so? Yes. Is it easier to mess something up by inducing too much heavy fluid? Also yes. For cleaning your intake tract and upper engine, you'll likely be better off with the Spray (which is also what I use it for) - spray it just before the throttle plate for best results.
You can use both simultaneously, as well, if you'd like. Not certain how much more effective this is, though.
charmz
Jul 4, 2013 03:01 PM
Kumar350
Sep 10, 2012 03:39 PM
baydriver
Dec 15, 2009 10:12 AM
Eric00GS3
Jun 18, 2006 04:19 PM
Ken'sGS300
GS - 1st Gen (1993-1997)
22
Mar 12, 2005 06:15 PM
