Bluetooth Audio
simple answer is no, use the search bar and look up the best ways to go about this. blue tooth music did happen untill 2009 in our cars
Molivacce (12-12-23)
designo (01-30-18)
I use this one because I dont need the USB function.
https://gromaudio.com/store/bt3_adap...e_adapter.html
i bought an aux bluetooth, it plugs into the aux and you can connnect to it via bluetooth to play music instead of a wire. you can connect to the car bluetooth as well so you can pick up calls.
https://www.amazon.com/AUKEY-Bluetooth-Receiver-Magnetic-Handsfree/dp/B0168GBMCY/ref=sr_1_3?ie=UTF8&qid=1518481535&sr=8-3&keywords=aukey+bluetooth+aux
i have that one. you can skip songs with it. i have it mounted next to my cup holder. and it stays plugged into the armrest so you dont have to charge it
Unfortunately, a lot of cars from this era are missing the proper codec needed to play music through Bluetooth. Personally, I use this --
Having a ground loop isolator is great to keep the static at bay. Hope this helps!
