How are gs350 for rust
AWD mid pipes do rust out if you do not remove the tin heat shield wrapping on them. Inside of that is fiberglass type matting that absorbs water and slowly rots the pipe.
Another thing to look after is the rear brakes floating pins tend to seize if you do not put grease inside of them.
