Two different tire tread depth...
Old Nov 10, 2017 | 03:40 AM
MiggzGS's Avatar
MiggzGS
Default Two different tire tread depth...
Need to replace my rear tires. Found a really good deal on some almost new used tires that have 9/32 and 10-11/32 depth.. I can save about $150 compare to if I buy 2 new tires for the same brand and model. Matching brand and model with same tread pattern... Is it okay to install and drive on tires with two different tread depth?
Old Nov 10, 2017 | 04:33 AM
ibidu1's Avatar
ibidu1
Should be fine
Old Nov 23, 2017 | 11:14 AM
ez12a's Avatar
ez12a
Only problem that might arise is if one is significantly worn more than the other and they're installed on the rear or drive wheels.
From your measurements it doesn't sound like that big of a diff. Make sure they're on the same axle though i.e. both on front or both on rear.
Caydoc
Mar 4, 2019 03:54 PM
bowenn13
Jun 24, 2012 08:30 PM
emg2919
Jan 8, 2012 07:35 PM
BlueCrabby
Wheels, Tires & Brakes Forum
Oct 29, 2011 08:00 PM
LIMS407
Sep 16, 2010 09:39 AM
