Check PCS Systems
8th Gear
Check PCS Systems
I own a 2009 GS460.
1)can any1 please tell me how to solve CHECK PCS SYSTEMS error.
2) unable to set cruise control. Error shows CHECK CRUISE SYSTEMS.
I couldn't find any switch under the dashboard on both side.
Appreciate if any 1 can help me on this.
i did a computer test with the local dealer and it does not show any fault.
would check the sensor and its connection
I believe that the sonar on your car is located inside the lexus emblem on the grill, check that up.
Give the sonar a good clean as well as cleaning the connection, being in the front its vulnerable to getting a lot of dirt.
Remember to disconnect your battery neg cable after you do the cleaning to clear up the codes.
Also I believe it was some TSB on the PCS, not sure if applies to your car tho:
http://www.alflash.com.ua/avtovideo/...PCSMessage.pdf
