Sharp Turn Music Turns Off
Old Nov 19, 2017 | 08:43 AM
Broncosi's Avatar
Broncosi
I got the head unit out today and did some house keeping. The main cable running from the head unit to the Vaistech brain was for some reason running between the radio unit and the metal bar (the typical no no when wiring in that area). No visible damage on the cable but unplugged the Vaistech and re-ran the cables below the metal bar and back to the head unit. I spot checked all other wires for the radio and visibly everything looks good. I did a bunch of jiggling and could not get the radio to cut off a single time. So no reason to believe there are any additional issues, besides the cable running between the head unit and the metal bar, at this time. I will update down the road again to see if this was the resolution to my radio cutting off and spitting out CDs.
Old Nov 20, 2017 | 06:00 PM
Gs3500's Avatar
Gs3500
Are u able to post some pictures?
Old Nov 22, 2017 | 07:28 AM
aneidiaz's Avatar
aneidiaz
My radio seems to turn off repeatedly as well. But I have stock everything. 2006 GS430. I've never had any work done to it other then an interlock breathalyzer machine for 6 months. Could that have possibly interfered with the back cable you guys speak of while the installation was being done? It had to do with the ignition. But I've never taken that radio unit out so i don't know exactly what that looks like back there. Only happens when I raise the volume up past 20. If that helps.
Old Nov 23, 2017 | 06:32 AM
aneidiaz's Avatar
aneidiaz
Where is the Vaistech brain located bro???
Old Nov 23, 2017 | 10:00 AM
ez12a's Avatar
ez12a
Viastech is aftermarket bluetooth or phone integration. If your car doesnt have this then I wouldnt worry about it.
I made a video on fixing my navi screen, with instructions on how to take the radio out, which would at least get you to all the connectors on the back.
Note, that the connectors are slightly different if you have Mark Levinson or not.
Old Nov 24, 2017 | 04:39 AM
aneidiaz's Avatar
aneidiaz
Very helpful video. Thank you so much bro! Again plz share what the conductive ink is for. I don't have that problem yet with the touch screen. But I'm interested in knowing why you did that. I think my problem is somewhere else. It's just my volume that pops when I put it up past 20 smh. Never happened to me before either until 2 days ago. I disconnected my battery for a lil while and it still does it. I'll have to see.
Old Nov 24, 2017 | 05:46 AM
Broncosi's Avatar
Broncosi
I didn't take any pictures. I'm sure there are some floating around. Here a screen shot from a install video. You can see the bar kind of. It rests against the bottom of the radio unit.
I have the brain unit wedged down into some free space under the ashtray.
My radio seems to turn off repeatedly as well. Only happens when I raise the volume up past 20. If that helps.
From what I've gathered, there are two scenarios here. One where the unit needs to be replaced and another where a wire is pinched or needs to be adjusted. I would take it out and while it's on, jiggle wires and move stuff around and see what happens.
The cable I adjusted was part of the Vaistech unit, not stock. When I installed it, for whatever reason, I ran it between the radio unit and that bar. If you do not have anything aftermarket behind your radio, there is a 99% chance that there's nothing running between the unit and bar for your setup.
Old Nov 26, 2017 | 12:39 PM
ez12a's Avatar
ez12a
It could be an issue with your amplifier maybe. When pushing at a certain level it cuts out. This is just a guess and i'm no audio expert. As for it cutting out when turning, i'd check the connections at the back
As far as the problem in my video, my touch screen stopped working, so nothing i pressed on the screen would work. It's a pretty common issue with the IS and GS and it is because the circuits in the ribbon cable that connects the digitizer (the thing that detects your presses) fails. You can repair the circuit using the conductive ink pen. It's worth trying before replacing the digitizer entirely which can lead to its own issues. It hasnt failed me since! *knock on wood*
Old Nov 26, 2017 | 02:47 PM
burny's Avatar
burny
Default Could your fingers
be hitting the buttons on the steering wheel when banking the turns?
Old Nov 27, 2017 | 05:49 PM
Broncosi's Avatar
Broncosi
Unfortunately there is no button on the steering wheel that kills the radio for a random amount of time between 1-5 minutes and ejects all CDs.
The good news is, since I've moved that cable, no random shut downs! I will report back again in the coming weeks.
Old Nov 28, 2017 | 05:18 AM
aneidiaz's Avatar
aneidiaz
Do you any pictures of that cable whole you had the display apart my friend??? Also I'm wondering, is there a fuse to the Amp by any chance????
Old Nov 28, 2017 | 03:44 PM
Broncosi's Avatar
Broncosi
I do not. As stated in my earlier post, I did not take any pictures. However, that should be irrelevant unless you had an aftermarket unit installed which you previously confirmed you didn't. The cable is just like a thick aux cable.
Old Dec 4, 2017 | 01:36 AM
aneidiaz's Avatar
aneidiaz
Originally Posted by broncosi
i do not. As stated in my earlier post, i did not take any pictures. However, that should be irrelevant unless you had an aftermarket unit installed which you previously confirmed you didn't. The cable is just like a thick aux cable.
bro is there any fuses to the amp or subwoofer that prevents the volume from going up to protect the unit?? I think maybe my subwoofer is blown?? I'm tryna figure this problem out so i can get to it logically. I don't think the amp is bad but then again it could be? All my sound is stock.
Old Dec 4, 2017 | 01:40 AM
aneidiaz's Avatar
aneidiaz
Originally Posted by ibidu1
a common problem on 3gs the radio plug looses contact, try putting dielectric grease on it
even for stock ml systems??? With no aftermarket work to it??
Pipboy
Aug 1, 2018 05:30 PM
PeteInGilr
RX - 3rd Gen (2010-2015)
Jul 3, 2014 12:40 PM
lwy72243
Jan 5, 2011 09:43 AM
RamshakleZ
May 31, 2007 01:27 PM
