Brake Upgrades
Old Jun 17, 2015 | 06:30 PM
xbladex00's Avatar
xbladex00
Originally Posted by LoveThatV8
Sexy ride you got there sir, what's the specs on wheel/tires? What brand wheels? Looking real good there. Haha
wow that looks good! do you know if the IS-F rear calipers fit onto stock GS350 rotors? I rather not deal with the seizing problem again!
Old Jun 17, 2015 | 08:44 PM
SoCal_450h's Avatar
SoCal_450h
Originally Posted by MrFuel
I upgraded my brakes to a full IS-F brake system, and wow what a huge difference in braking power.
Agreed..and they're look good
Old Jun 21, 2015 | 10:23 PM
MrFuel's Avatar
MrFuel
The stock rear rotors won't work. They is-f ones are bigger all around. I know this, cause I had to transfer over the isf rear dust sheild to fit the isf rotor.
Old Jun 21, 2015 | 10:25 PM
MrFuel's Avatar
MrFuel
Thank you, my wheels are Work GNOSIS CV202 19x10 19x11 +20
Old Jun 22, 2015 | 03:53 PM
sprtn131's Avatar
sprtn131
I thought about doing a 350 swap. ..
But it was going to be more then i wanted to spend, ended up doing drilled and slotted. A lot better pedal feel then stock
Old Aug 6, 2015 | 08:22 PM
LoveThatV8's Avatar
LoveThatV8
I'm due for maintenance on my brakes, figured to ask what's the best site to order rotors from? I've seen peeps run stoptech rotors with akebono pads, wanted to run the same set up. Suggestions? Rockauto? Autoanything?
Old Aug 8, 2015 | 03:40 PM
xbladex00's Avatar
xbladex00
I bought power stop rotors and they came with pads the whole set was about 200-300$ So far so good, everything fits. They sort of mimic the OEM ones except the front is different with a circular vent around the center hub.
Old Aug 10, 2015 | 03:11 AM
LoveThatV8's Avatar
LoveThatV8
Cool deal man, what website did you get this from?
Old Aug 12, 2015 | 10:08 AM
masboy's Avatar
masboy
CL Folding 25,000
LoveThatV8, since u r in socal, get the rotors from R1 Concept.
Been using R1 concept on all my cars for years now.
and Akebono for pads
Old Aug 26, 2015 | 12:09 PM
Futura Design Brakes's Avatar
Former Sponsor
Originally Posted by RudeMood
What does that have to do with anything?
NickTee was referring to your tires potentially being the "weakest link" and no amount of brake upgrades would make a difference if the tires are not up to the task.
S to the K
Suspension and Brakes
May 23, 2008 08:47 PM
Lexus400mn
Jun 4, 2007 12:26 AM
shoehead
Wheels, Tires & Brakes Forum
Sep 30, 2005 12:13 AM
Black_IS300
Jun 29, 2001 09:12 PM
