soft brake pedal?
Old Mar 23, 2015 | 08:23 AM
xbladex00's Avatar
xbladex00
Default soft brake pedal?
Does anyone feel that the brake pedal is soft? I press it slowly and its soft but when i press quickly its harder any solutions? I recently replaced my rear calipers too
Old Mar 24, 2015 | 06:52 PM
TRD_Power's Avatar
TRD_Power
Probably some air in the brake lines. Try bleeding them.
Old Mar 24, 2015 | 07:11 PM
xbladex00's Avatar
xbladex00
when I replaced the rear calipers I only bleed the rear two that i replaced... I bleed them until there was no more air coming from them... so I might still have air in the system....
Old Mar 25, 2015 | 08:06 AM
TRD_Power's Avatar
TRD_Power
It's definitely possible that some was missed. Maybe a flush on all the lines would be a good idea, just to be safe
Old Mar 25, 2015 | 09:21 PM
xbladex00's Avatar
xbladex00
hmm I think about to change my front brake pads... While I do that I'm going to flush the brake fluid... after driving it for God knows how many years with seized rear calipers I'm sure I've been using the front calipers 100%
Old Mar 28, 2015 | 02:54 AM
ToneTham's Avatar
ToneTham
I have the same problem. Its squishy bro. I recall a moment coming down from grapvines on both la and bakersfoeld side and I would get a vibration when I broke really hard on a decline. Have you thought about resurfacing or replacing your rotors. Maybe drilled and slotted. I have but I have not done that yet
Old Mar 28, 2015 | 05:48 PM
xbladex00's Avatar
xbladex00
haven't replaced my rotors yet.... I've replaced the rear calipers and that was my main problem... brakes work okay... they just sort of have no feed back pressing it like 1/8 of the way even know I'm decreasing in speed, but they seize in the cold still... maybe your rears calipers are seized too? Or maybe prolong aggressive driving has caused some brake fade.... vibration is most likely abs kicking in... was the traction light going off??? I heard I shouldn't resurface my rotors... I'm not sure when the last time they were changed or resurfaced... I only started driving this car about 3 years ago and started noticing these symptoms...
stnick007
Mar 2, 2018 06:03 PM
See5
Suspension and Brakes
15
Mar 21, 2016 03:57 PM
Azhar22
Jan 12, 2014 07:55 AM
Ag02M5
Maintenance
Aug 12, 2003 06:14 PM
