Richard. lol, Did you notice there are no Starter contacts for this car. I did see a rebuild kit on the Sewell site and it was $70 or so. Looked like the entire solenoid piece of the starter? Contacts must be embedded in that bad boy. What say you?
I am hearing the bearing is what is failing on these alternators. Sewells has the bearing for like $12 so I guess I'll do the bearing and the contacts. There is a youtube video on how to replace the bearing.
Sewell lists one Bearing at 9006810033 which has new number 90099-10223. This is the front larger bearing. They do not show the rotor bearing in the back of unit as some other vehicles do. Does anyone know the part number for that one or even the dimensions? If you look at 9099-10140(rotor bearing for GX470), this is the bearing I need for the GS350 but don't have the correct part # for a GS350 and it is not on the site.
I had been smelling a faint burning smell. Had the car checked and nothing was found. 2 days later my battery light came on and the car died on me on the freeway. I had it towed to an independent shop that specializes in Lexus cars. They replaced the alternator and the serpentine belt and I paid $800. The Lexus dealership wanted $1500. The only problem I had afterwards was that it shorted my navigation system. They changed a fuse and all seems ok with the exception that the volume on the radio will iintermittenly go off for a few minutes and then turn back on.
I am planning to rebuild mine in next month or so. Ordered the front cover plate from Sewells with the bearing already pressed in for $18. Already had the brush ring.
i had mine replace at the dealer only because i bought a warranty(not through dealer) with my 07 GS350. went out at about 80k. was about $1100 from the stealership. only paid $100 deductible. i was hoping it was the battery so i towed car to dealer, was alt. so i remembered i bought a warrant and it was covered. if not i would have had my friend swap it out since i needed the car ASAP for work. this was in november.
at least they washed and gave me a full tank of gas. an $80 value.
