Replacing rear trunk button?
Old Aug 12, 2013 | 09:38 PM
uncandid's Avatar
uncandid
Default Replacing rear trunk button?
Anyone ever replace the trunk button on the trunk lid? Its the one with the rubber button. I've searched but haven't found anyone with a DIY? I know the trunk lid lining has the be removed but not sure how to remove that either. Any help would be appreciated. thanks
Old Aug 13, 2013 | 08:34 AM
jamodeo's Avatar
jamodeo
I have not, but from the pictures here it looks like you have to take two screws out, and yes remove the liner, than just swap that plug.
-Joe
Old Aug 13, 2013 | 11:28 AM
ibidu1's Avatar
ibidu1
Have you tested the switch to make sure that it is the cause of your problem? If not you can buy a volt meter and test the connections before you go replacing parts.
Old Aug 14, 2013 | 04:52 PM
kelleher2's Avatar
kelleher2
just bought a 2008 LS460 with the same problem. Let me know what you find out please
Old Aug 14, 2013 | 04:55 PM
ibidu1's Avatar
ibidu1
There is a valet button in the glove box make sure that is not pressed or your truck will not operate
Old Aug 16, 2013 | 08:40 PM
GS10101111's Avatar
GS10101111
Default Not just two screws....
I just got my 2008 GS 350 3 weeks ago, first thing I did was replace trunk switch. I replaced this switch due to the condition of the rubber cover on the switch. It turns out that you cannot buy the rubber cover itself, you must replace entire switch assembly. Do yourself a favor order the switch of ebay, do not pay the stealership!
Replacing the switch assembly involves removing more than the inner liner, you practically disassemble the trunk lid. I did not have time to make a DIY, and I will not be doing it over any time soon. Suffices to say that you must remove the inner liner the trunk portion of the rear lights, the trunk lid finisher, and the tag light/trunk switch assembly.
Note: As for the two screws aforementioned, for some reason they were very difficult to remove. Be sure and use a number one phillips on them.
Old Aug 17, 2013 | 09:15 PM
uncandid's Avatar
uncandid
The rubber cover is the exact reason I am replacing it. Thanks for the tips. I'll try it this weekend. thanks
knguyenk
Dec 1, 2019 08:55 AM
g26
Apr 7, 2013 07:21 PM
intellect
Jan 29, 2010 10:07 AM
indelible
May 19, 2009 10:32 AM
rclab1
Jul 7, 2006 08:22 AM
