Maximum size spacers
Old Feb 22, 2012 | 06:05 AM
gridlock13's Avatar
gridlock13
Default Maximum size spacers
i'm thinking of putting spacers on my rear wheels to push them out a bit more. right now i have 19x8.5 wheels with +38 offset and 245/35/19 tires at all 4 corners. after doing some calculations i think the maximum sized spacers i can put on the rear wheels are 19mm without having to do any fender mods. can anybody tell me if this is correct?
Old Feb 22, 2012 | 01:42 PM
adamls2's Avatar
adamls2
Did you measure the wheel gap??
Old Feb 22, 2012 | 02:41 PM
mrbulk's Avatar
mrbulk
Depending on how the car will be used, spacers are either cool or absolutely evil. I used to be into Mustangs (Cobras, GTs and finally a Mach1) and spacers make a car look great and corner better. Drove around with'em for years. But I did lose a rear wheel once when racing, not a pleasant thing. You should retorque after the first 50-100 mikles after install, and then periodically after that.
JMHO from personal experience...
Old Feb 22, 2012 | 05:26 PM
gridlock13's Avatar
gridlock13
no i didn't. i haven't put on my summer wheels yet. but there's a member on here running 19x10 with +43 offset on 275/30/19 wheels in the back with no rubbing or fender mods. long story short, i did some calculations and thought 19mm is the maximum amount i could push the wheels out. was hoping the experts here would be able to shine some light on this.
btw the car will never be tracked or raced so hard cornering will rarely happen. thanks for the tip though mrbulk
davyjordi
Aug 6, 2017 03:52 PM
Gplex1987
Jul 8, 2012 06:35 PM
Split2nd
Apr 14, 2012 11:27 PM
Pearl250
May 6, 2010 07:45 PM
corkycal
Wheels, Tires & Brakes Forum
Aug 5, 2004 12:59 PM
