Vibration between 2nd and 3rd gear
Old Jul 13, 2011 | 04:36 PM
LenniePaz's Avatar
LenniePaz
Default Vibration between 2nd and 3rd gear
I just noticed a slight vibration when going at lower speeds between 2nd and 3rd gear. If I am accelerating at a decent speed the vibration is not there. I also noticed it going up a hill at a lower speed but as soon as I gave it more gas, the vibration went away. Anyone else notice this? 2007 GS350 AWD by the way.
Old Jul 14, 2011 | 04:10 AM
lkapimp216's Avatar
lkapimp216
Rear tire could be out of balance or could be a bad tire Im having a similar problem but it's cause I have a bad tire.
Old Jul 14, 2011 | 08:14 AM
designo's Avatar
designo
Drive shaft?
Old Jul 14, 2011 | 08:22 AM
jnaval's Avatar
jnaval
It could be something as simple as loose lug nuts, eliminate the most common and obvious causes.
Old Jul 14, 2011 | 08:35 AM
MichaelPea's Avatar
MichaelPea
In all honesty, i don't know if the GS even has a locking rear diff but if it does, it sounds a little like you may need some additive. My guess is that it doesn't have a true locker since it has trac control but it might anyway.
lbintab
Aug 9, 2020 12:46 PM
Omar89
May 20, 2016 01:35 AM
09IS250RWD
Apr 27, 2016 03:36 PM
solotallbo
Jan 17, 2010 06:19 PM
solotallbo
Nov 7, 2009 08:52 AM
