Wheel offset help
Old Jun 22, 2011 | 02:16 PM
Rider's Avatar
Rider
Designo - Your stance looks great, but I was hoping for an aggressive stance without the need for spacers/fender mods.
lkapimp216 - This is what they offer:
19x8.5 5x112 45
19x8.5 5x4.5 45
19x8.5 5x4.5 30
19x9.5 5x120 45
19x9.5 5x112 45
19x9.5 5x4.5 45
19x9.5 5x4.5 35
19x9.5 5x4.5 25
19x10.5 5x4.5 33
19x10.5 5x4.5 22
What do you recommend?
Old Jun 22, 2011 | 02:27 PM
Mike1970's Avatar
Mike1970
im running 19x8.5 +32 10mm spacer with a 225/35/19 and a 19x10 +32 245/35/19 the back is perfect no spacer the front you could do a 19x9 +32. i did finder roll no pull though
Old Jun 22, 2011 | 05:42 PM
lkapimp216's Avatar
lkapimp216
You need a 5x114.3 your options are better in the 20 than the 19 there are no 19x10
the 20x8.5+20 and 20x10+35 would be ideal but I don t see it in the right bolt pattern thus leaving you with a 20x10+43, you could use the 20x10+25 but you would need to run a 245/30 or 235/30 on the rear and may need to slightly shave the rear fenders but would look great. with the +35 or +43 you would be able to run a 285/25-20 on the rear and a 245/30-20 front and to be honest 20s are the ideal size for this car. With these rims and tire sizes your speedo and car will be within factory spec. I highly recomend Vredestine tires they are durable,quiet, and stick to the road. they also have a more curved sidewall giving you more clearance in the fender well. I have very hands on input when giving advice on this car and fitment I have had 3 set of wheels and another on the way not including factory set up. I have ran spacers from 5mm to 20mm and even had one customized and milled down 2.5 mm to create the 12.5mm spacer on the rear of my car now that allows me to achieve the most aggressive stance with a shaved fender and no aftermarket camber arms, and no fender pull.
Attached Thumbnails Wheel offset help-dsc_0149-800x531-.jpg   Wheel offset help-dsc_0147-800x531-.jpg
Old Jun 23, 2011 | 04:58 AM
Rider's Avatar
Rider
I prefer sticking with the 19s.. how about 19x9.5+ 25 all around?
Old Jun 23, 2011 | 05:03 AM
designo's Avatar
designo
Rider, you're gonna regret saying the word "spacer"! Take it from me brother... AVOID THEM!!!!
Old Jun 23, 2011 | 06:52 AM
lkapimp216's Avatar
lkapimp216
The front would be aggressive and the rear would be weak a whole inch more sunken in then my fitment on the rear. A 9.5 +25 on the front is 7mm more conservative than my front
Old Jun 23, 2011 | 05:20 PM
Rider's Avatar
Rider
Ahh this is confusing haha... From the above stances... which do you recommend I go with?
Old Jun 24, 2011 | 03:50 AM
lkapimp216's Avatar
lkapimp216
I was wrong about the rears, they will only be 1/2 inch more sunken in in the rear and 1/4 in the front it should look good with the drop your going with! You could always add spacers to fine tweak it I ve had 4 sets and never a vibration.
Old Jun 24, 2011 | 04:09 AM
IXI187IXI's Avatar
IXI187IXI
i think you really need to use a offset calculator
this will show you what you need to know. plug in your stock wheel and tire set up and then for the second one, what you would like. it will show you the difference between the 2.
Old Jun 24, 2011 | 07:30 AM
Rider's Avatar
Rider
so 19x9.5+25 all around with 245/35 and 275/30 will work?
Old Jun 24, 2011 | 07:51 AM
IXI187IXI's Avatar
IXI187IXI
if your doing the same size wheel all around, why get 2 different size tires?
Old Jun 24, 2011 | 08:12 AM
lkapimp216's Avatar
lkapimp216
187 is right go with the 245/35-19 all around if your going with the same rim front and rear
Old Jun 24, 2011 | 10:01 AM
designo's Avatar
designo
Rider, seriously bro! I wouldn't get too shy with your GS.
She's crying out for 22" spinners!
Old Jun 24, 2011 | 03:20 PM
Rider's Avatar
Rider
hmm.. coz i wanted a wider tire for the rear section.. stock size looks too tiny! so I guess two different tire sizes wont work?... bare with me guys im a total newb when it comes to such stuff.
Haha.. I dont see that happening anytime soon bro!
Old Jun 25, 2011 | 06:33 PM
Rider's Avatar
Rider
Can i go with 275/30 all around?
