Need Advice - rearview mirror shakes
Old Oct 8, 2010 | 12:21 PM
DWNYC's Avatar
DWNYC
I was told there is a bracket that is part of the windshiled that the mirror attaches to. It's this bracket they say is not fitting well even after they tightened it. It is much better now and I can live with the minor vibrations. My thought was that this was a good opportunity to get the mirror vibration fixed with the benefit of new glass. The glass is a little pitted which can be seen when it is sunny. But I tend to avoid breaking the factory seal if it is not necessary.
Old Nov 17, 2010 | 06:38 PM
bigjohnsd's Avatar
bigjohnsd
INNER REAR VIEW MIRROR > REMOVAL
1. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
CAUTION:
Wait at least 90 seconds after disconnecting the cable from the negative (-) battery terminal to prevent airbag and seat belt pretensioner activation.
2. REMOVE INNER REAR VIEW MIRROR COVER
Pull the cover in the direction indicated by the arrow in the illustration. Then remove the cover.
3. REMOVE FRONT ROOFTOP GARNISH
w/ Rain sensor:Remove the top garnish.
Using a screwdriver, detach the 3 claws and 2 clips, and remove the top garnish.
HINT:Tape the screwdriver tip before use.
w/o Rain sensor:Remove the top garnish.
4. REMOVE PERSONAL LIGHT ASSEMBLY
Using a screwdriver, remove the 2 covers and 2 screws.
Using a moulding remover, detach the 2 clips and 3 claws.
Disconnect the connector and remove the personal light.
5. REMOVE INNER REAR VIEW MIRROR ASSEMBLY
Remove the screw.
Disconnect the connector and remove the mirror.
Old Nov 17, 2010 | 08:01 PM
Aristo82's Avatar
Aristo82
Thanks for the instructions, but I was able to locate the screw last week after looking around at another forum that explained how another Lexus/Toyota model had theirs attached. I should have looked more carefully the first time around!
I didn't take pictures, but it is located right behind the rearview mirror. It is recessed in a bit so you may need a flashlight to visually see the hex screw.
Just screwed it in maybe 1/2 turn - no more vibration while driving!
Old Nov 23, 2010 | 05:10 AM
MadDawg350's Avatar
MadDawg350
Originally Posted by Aristo82
......located right behind the rearview mirror. It is recessed in a bit so you may need a flashlight to visually see the hex screw.
Saw this fix, tried it and it works. No more vibration!!! All it took was a T-20 sized star bit and less than a 1/2 turn.
Old Nov 23, 2010 | 06:19 AM
IXI187IXI's Avatar
IXI187IXI
hmmm... i may have to do this. mine vibrates like crazy even when no music is on. when i drive its almost impossible to use the rear view mirror.
this screw that you are tightening, do you have to remove anything to get to it or is it just behind the mirror itself?
Old Nov 23, 2010 | 07:24 AM
BinaryJay's Avatar
BinaryJay
A friend of mine just told me that he just got a recall notice for his little Suzuki for ... rearview mirror vibrating. Is it possible that this is next on Toyota's list? (Mine never vibrates... knocking on wood.)
Edit: Oops, I must have misunderstood him... I looked it up, it's the side mirrors apparently falling off.
http://www.autoblog.com/2010/10/29/s...mirror-screws/
Old Aug 15, 2013 | 07:49 PM
DrewGS350's Avatar
DrewGS350
I have an 08 GS350 and I just had my rearview mirror replaced due to vibrating under warranty. Mine however only vibrated when the mirror was hot. Still can't figure that out. It still vibrates when it's hot. Just tried tightening that screw. It did tighten so will see if it does the trick.
TLRD
Apr 12, 2020 11:53 AM
SC400_2nV
Jul 23, 2014 02:06 PM
stevies30
Oct 12, 2005 08:26 PM
