Vossen Wheel with + spacer
Old Sep 25, 2010 | 02:39 PM
  #31
I8ABMR's Avatar
I8ABMR
Ron your ride is amazing. It keeps getting better and better and better. Nice work buddy. When you said that the show was cancelled was this the extreme auto fest for 10/02/10???
Old Sep 25, 2010 | 03:25 PM
  #32
TriniGS's Avatar
TriniGS
Originally Posted by ryan78
funny, i have +20 on a 9" wheel for my fronts, and i added a 5mm spacer. could almost use another 2 to 3mm. rears are 10.5 +25, and they are pretty much as flush as i want them. +20 would be awesome, but would require more work to fit. they look good at that offset though!
Geez did not know those were the offsets you were running. Wow +20 with spacers and +25. What size tires are on the wheels?
Old Sep 26, 2010 | 12:30 PM
  #33
Hoovey689's Avatar
Hoovey689
2UR-GSE Owner
amazing looking stance and fitment!!
Old Sep 26, 2010 | 12:31 PM
  #34
1STLXS's Avatar
1STLXS
Thanks Tammer...that is correct on Extreme
Same question I have. I put the 15mm spacers on the front and am poking slightly. Here are the pics. +32 w/15mm spacer = +17
Attached Thumbnails Vossen Wheel with + spacer-job-pics-025.jpg   Vossen Wheel with + spacer-job-pics-026.jpg   Vossen Wheel with + spacer-job-pics-037.jpg   Vossen Wheel with + spacer-job-pics-041.jpg   Vossen Wheel with + spacer-job-pics-042.jpg
Old Sep 26, 2010 | 03:07 PM
  #35
ek9vboi's Avatar
ek9vboi
Lower it more and the poking will go away. Mine was on point when we did it, but I'm a lot lower.
Old Sep 26, 2010 | 03:55 PM
  #36
rominl's Avatar
rominl
exclusive matchup
yup, camber helps
Old Sep 26, 2010 | 04:33 PM
  #37
1STLXS's Avatar
1STLXS
Also going with stretched tires would definitely help but that is something I have decided not to do. So for now I will just use the spacers when entering car shows. This has definitely helped in determining my next set of wheels, though
Old Sep 26, 2010 | 05:02 PM
  #38
passnu2's Avatar
passnu2
yea you will need to stretch the fronts when you go lower. I have some camber arms that will give you more negative camber to help those fit need them out of the garage so I can use the $$ for my new project
Old Sep 26, 2010 | 11:33 PM
  #39
ek9vboi's Avatar
ek9vboi
Running the proper tire size and lets says a 235/30 would be nice, along with a 275/25 would look great.
Old Sep 28, 2010 | 02:19 PM
  #40
swtjlsy's Avatar
swtjlsy
remember the poking in mean less tire life
Old Sep 28, 2010 | 02:52 PM
  #41
lkapimp216's Avatar
lkapimp216
I don t think they make a 275/25 only a 275/30 you would have to go with a 285/25. I was sold on the vredestine tire because it has a rounder sidewall
Old Sep 28, 2010 | 04:18 PM
  #42
TWong350's Avatar
TWong350
CL Folding 10,000
Not true...SOME manufacturers make 275/25/20. It seems to be a more rare size. Just google 275/25/20 and you'll see lots of hits.
Old Sep 28, 2010 | 04:45 PM
  #43
lkapimp216's Avatar
lkapimp216
Yep I was wrong, however it is a rare size and there is only and handful of companies that make it and it will be expensive. They don t make a 275/25-22 cause I was looking for that along with a 225/30-22 that only lexani makes and its been on back order for a year now! part of the reason I abandoned the whole 22 idea cause I can t get them to fit like I want, they were made at 8.5 and 9.5 so i couldn t get a tire to fit like I wanted to sit flush, Oh well!!!
Old Sep 28, 2010 | 08:19 PM
  #44
ek9vboi's Avatar
ek9vboi
Tires are the more important part of having wheels IMO. Some people go extra cheap on it... falken being almost the lowest. Yes, I am one of those but the next set will be Toyos or Nittos.
Nitto makes a 275/25/20 and from what I've heard from other users, its a quiet and grippy tire.
Go big or go home.
Old Sep 29, 2010 | 03:32 AM
  #45
ryan78's Avatar
ryan78
running 225/35F and 265/30R.
