Satellite Radio question
Old Feb 26, 2010 | 04:44 PM
Bambigular's Avatar
Bambigular
Default Satellite Radio question
Just bought 06 GS 300 No Nav or ML. I was wondering having the satellite buttom doesn't necessarily mean I have the satellite tuner..right? I tuned the radio to 000 to try to get the radio ID# but nothing. I tried it in am, fm1, and fm2. Am i doing something wrong or do I just not have satellite radio??
Old Feb 26, 2010 | 05:36 PM
rominl's Avatar
rominl
exclusive matchup
correct, that only means your car is sat radio ready. the tuner is most likely not there.
so you either need the factory tuner / antenna setup, or go aftermarket
Old Feb 26, 2010 | 07:24 PM
R.DUB's Avatar
R.DUB
so the sat button will also work with aftermarket?
Old Feb 26, 2010 | 07:45 PM
EyeKutr's Avatar
EyeKutr
I tuned the radio to 000 to try to get the radio ID# but nothing. ??
When you press SAT, what do you see on the display ? Does it actually change to SAT ch 001 or whatever ? if it does, it means you have the tuner. If nothing happens you dont have the tuner. Also on the 06 gs300 sirius antenna was a huge triangle thing on the front windshield, sometimes something on the rear deck or trunk lid.
Old Feb 26, 2010 | 11:55 PM
rominl's Avatar
rominl
exclusive matchup
if you get stuff like vaistech, it doesn't really matter if your car has the AM-SAT button or not
good point. i think without the tuner you can't even get into sat mode. when you press the button it will just keep in AM
Old Feb 27, 2010 | 01:26 PM
ingoodtime's Avatar
ingoodtime
go to tss-radio.com I purchased two
systems for our gs and es for sirius and ipod.
cost about 230.00 plus installation by besybuy
was about85.00
Old Feb 27, 2010 | 07:24 PM
levinsoy's Avatar
levinsoy
was about85.00
Hey, I looked on that site, what exactly did you purchase from them (name or model #)? Does it work with the factory system allowing you to use the steering wheel controls?
Thanks!
Old Feb 28, 2010 | 08:21 AM
ingoodtime's Avatar
ingoodtime
Thanks!
I have the factory touchscreen radio, no nav, no ML. If you want Sirius radio, be sure your factory radio faceplate does not have XM printed anywhere on it. Secondly, you must have the AM-SAT button on the factory radio,
I also wanted connectivity for my IPOD touch 2nd gen.
I ordered a PXAMTYA ISIMPLE media gateway TY1 Sirius Connect Kit. I think list is 229.99 and shipping is free. This fit both my 06 GS300 and ,y wifes 07 ES350 non touch screen radio.
The kit consists of a media gateway, harness Sirius connect cable and sirius connect tuner. The antenna comes with the tuner. The kit will fit in the dash behind your factory radio so you have the factory look,
Opted to have my antenna (magnet mount) put on my passenger side front speaker near the windshield. It works well although I may get a moment or two of acquiring signal more often than I did in my last car which had the factory radio on the roof. But, being away from the elements, the inside antenna should last longer than an outside non factory antenna.
Hope this helps. I'll bet they would be open to a group buy as I did get a discount for buying more than kit.
Hope this helps everyone.
Old Feb 28, 2010 | 07:13 PM
yogregb's Avatar
yogregb
FYI, the factory sat tuner kit is no longer available for the 2006, I know because I wanted one to install in the trunk myself. Swell lexus shows the kit dis-continued as well as my local so cal dealer. Anyone with info on how to come up with one, please let me know!!
Old Feb 28, 2010 | 07:55 PM
KeysRx300's Avatar
KeysRx300
Default Xm
You might also try eBay. Ive seen all types of radios tuners.
Also you might want to go Sirius. They are the same company. But they are still run like two different companies. With different programming.
Old Feb 28, 2010 | 09:31 PM
rominl's Avatar
rominl
exclusive matchup
if anything you can still go with vaistech xm version, price wise it's about the same
johnnylt
Aug 28, 2015 03:54 PM
georgewap
May 10, 2014 01:46 PM
1flossedm3
Sep 12, 2011 04:19 PM
mercclk6
Feb 4, 2009 09:50 AM
rennan
Jun 8, 2004 08:02 PM
