Help!!! Vent modes not working
Old 11-30-09, 12:19 PM
VIPNiSS
VIPNiSS's Avatar
Default Help!!! Vent modes not working
My A/C vent modes are not working. I can set the mode to blow at the face, feet, face and feet, and etc.. none of the combinations work. The only air that comes out is from the defrost vents.
Also sometimes when I start the car the front defrost button just blinks yellow for about 10-20 seconds and will not respond to any buttons that i push that is apart of the climate.
Everything else still works just fine. A/C and Heat but it just wont let me change the position of where the air blows out of.
Any ideas?
Old 11-30-09, 12:26 PM
jtrue28
jtrue28's Avatar
do you have it on "AUTO"?
Old 11-30-09, 12:28 PM
VIPNiSS
VIPNiSS's Avatar
AUTO or not it still does it.
Old 11-30-09, 12:33 PM
passnu2
passnu2's Avatar
only thing I can think of is there is a "servo" (assuming thats what its called) that basically moves the stuff around as you change from feet, vent, ect....
Do you have any wires behind your stereo/navi unit that may have got stuck? Its possible a loose wire or something may have gotten stuck between the servo as it was trying to move and its now stuck or broken? If not take it to the dealer assuming you have warranty or CPO.
Outside of this I am not sure what else is causing this.
Old 11-30-09, 12:40 PM
VIPNiSS
VIPNiSS's Avatar
I have extended warranty but its $100 deductible. I didn't know if it was something simple and was a quick fix.
Old 11-30-09, 12:54 PM
passnu2
passnu2's Avatar
^ can you take out the unit to see? Its not hard to remove and its possible you may find what is going on. Or if you cant find anything wrong maybe pull the fuse or the plugs in the back of the unit to see if it will reset. Not sure it will do anything but it cant hurt to try.
Old 11-30-09, 04:10 PM
I8ABMR
I8ABMR's Avatar
for a 100 dollar deductible I would rather have certified Lexus tech fix it for you. Sounds like you may have a small issue with the system
Old 11-30-09, 08:50 PM
VIPNiSS
VIPNiSS's Avatar
yeah.. i think i will take the plunge and have the dealer fix it.
Old 12-08-09, 12:17 PM
waijai
waijai's Avatar
Are you out of your regular warranty Tommy?
Old 12-08-09, 12:44 PM
VIPNiSS
VIPNiSS's Avatar
Yeah. But I do have extended
Old 12-08-09, 12:51 PM
IXI187IXI
IXI187IXI's Avatar
so did you take it in? kinda curious to see what the problem is.
$100 deductable is not bad considering what the price for the parts are for these cars.
Old 11-11-17, 06:12 AM
topperdogg
topperdogg's Avatar
I know I'm a bit late to the party, but did you find what the issue was? This is exactly what happens on my car. I pulled out the mode servo (driver's side) and it does work when dangling (not trying to turn the cogs). When I try to turn the cog by hand, it's pretty stuck. No idea where to turn next, also considering going to the dealer.
Old 07-26-18, 01:24 PM
lexpanic
lexpanic's Avatar
Cool thanks for making this thread I think when I changed out my stereo I probably jammed one of the wires from my stereo harness into the mode servo motor and messed it up!
Old 05-02-23, 10:37 PM
Japmand
Japmand's Avatar
I had this same problem today. I'm going on a hunch here, but I'm thinking it's the remote start wiring getting jammed up in one of the flappers. Makes a slight click noise when trying to move, then it just gives up trying. Stuck on windshield defrost mode and that button flashes sometimes. i held it down and the selection options came back. Will diagnose in the next couple days.
Just found this one too:
https://www.clublexus.com/forums/gs-...o-replace.html
Solution: Pulled the remote start down and moved it to the left behind the dead pedal. It must have been hitting something up to the right of the gas pedal. Found out my recirculation door is broken, but I never use "fresh" (stinky exhaust smelling) air anyway, so I think I'm going to leave it shut.
slosu
06-16-11 11:51 AM
Clear2Cloz
04-05-09 05:03 PM
uplusd
02-18-07 09:54 AM
BlkGS3
11-14-05 06:01 AM
lexusdr
GX - 1st Gen (2003-2009)
03-06-05 09:33 AM
Quick Reply: Help!!! Vent modes not working
