when is it time for new brakes?
Old Aug 9, 2009 | 11:15 PM
Johnnyz4's Avatar
Johnnyz4
Default when is it time for new brakes?
What is a good indicator that it is time for new brakes? Can you tell by just looking at them? and how many miles on avg do brake pads last?
Old Aug 10, 2009 | 06:32 AM
stvincent's Avatar
stvincent
there's a piece of metal that acts as an indicator for brake pads.. with low amount of pads left, it makes a screeching noise as that metal piece being exposed to rotors..
Old Aug 10, 2009 | 10:05 AM
TWong350's Avatar
TWong350
CL Folding 10,000
Unless that tab breaks off, which is common.
Old Aug 10, 2009 | 10:49 AM
LexFather
Guest
Posts: n/a
When the brakes start squeeling. It depends on usage but expect 50-60k on the pads.
Old Aug 10, 2009 | 11:09 AM
jre002's Avatar
jre002
Or the most obvious indicator... which is decreased brake performance, i.e.- additional brake pedal travel, vibration during braking...
May or may not be directly related to the pads. It could be warped rotors, low fluid, etc... Depends on the symptoms.
Old Aug 10, 2009 | 02:35 PM
Yang1815's Avatar
Yang1815
or u can look at the pads and see how much of it is left.
Old Aug 11, 2009 | 01:20 PM
HalfSleep's Avatar
HalfSleep
that would be suggestion too ... i visually check the brakes during every rotation and/or swap between summer/winters.
MrKayP
Suspension and Brakes
22
Apr 21, 2022 12:48 PM
deeken
GX - 1st Gen (2003-2009)
Jul 14, 2018 05:35 AM
GS300 I6
Maintenance
Dec 22, 2009 05:37 PM
Kharizma
Dec 16, 2005 12:01 AM
HoleinOne
Mar 10, 2004 10:54 AM
