3GS wheel thread
Old Mar 5, 2020 | 01:52 PM
  #2116
msgs350's Avatar
msgs350
Originally Posted by susfuuuk
I have a RWD GS350. so I was looking around the internet and found these wheels for a steal of a price and was wondering would these wheels fit with little to no cutting/rolling done. Also I will be on air soon.
Wheel specs:
20x10 +24
20x10.5 +18
Tires:
245/35
235/35
Gonna need a roll/pull at the least for those to fit.
Old Mar 10, 2020 | 10:15 AM
  #2117
GSjohnny's Avatar
GSjohnny
Default Another fitment Question
Hey guys. I know its been asked countless times but haven't seen anyone running this setup on 07 GS350 or similar?
Dropped on NF210
Wheels STR 607s
Front 20x9 offset 35 Lexani tires 245/30
Rear 20x10.5 offset 40 Lexani tires 285/35
Any rubbing issue or fender mods needed?
Old Mar 10, 2020 | 10:57 AM
  #2118
msgs350's Avatar
msgs350
Dropped on NF210
Wheels STR 607s
Front should be fine but rear may need to shave/roll a little bit.
Old Mar 10, 2020 | 11:16 AM
  #2119
chrispy's Avatar
chrispy
Wheel specs:
20x10 +24
20x10.5 +18
Tires:
245/35
235/35
These wheels are a scam on Craigslist. Do not buy and report them to the police.
Old Mar 10, 2020 | 06:23 PM
  #2120
GSjohnny's Avatar
GSjohnny
Update. Just tried them on and rears would not even fit on lugs. Tire was hitting front of wheel well. UGH!
Old Mar 19, 2020 | 04:20 PM
  #2121
robloc93's Avatar
robloc93
Aodhan DS01 19x9.5 +15 front, 245/35r19 and 19x10.5+22 rear 273/30r19 Rainy Day shots
Old Mar 22, 2020 | 02:57 PM
  #2122
KidWeaBoo's Avatar
KidWeaBoo
What offset do I need to get a flush look on stock size 18x8 wheels?
Old Mar 22, 2020 | 06:43 PM
  #2123
AspireXVIP's Avatar
AspireXVIP
I have concave profile 19x8.5 +38 offset. 18x8 isn't enough to give you a "flush" look. I use 1 in. spacers on my wheels to clear the calipers and to achieve that flush look. The offset determines how far the rim is from the center. Do you have a set of rims in mind. Are you planning on using deep dish wheels?
Old Mar 22, 2020 | 07:50 PM
  #2124
KidWeaBoo's Avatar
KidWeaBoo
https://pmctire.com/en/wheels/fastwh...t-40-72-6.tire looking at getting these. Planning on sticking to the stick size for the ride.
Old Mar 22, 2020 | 09:03 PM
  #2125
AspireXVIP's Avatar
AspireXVIP
Those are nice. In an 18x8 they're not gonna be flush with the fenders. I run the H&R spacers so I can run a square setup and be able to rotate my tires. While H&R is a reputable company, I get vibrations sometimes. Im thinking of running a staggered setup so I can do away with the spacers. 19's dont ruin the ride honestly as long as you go with a nice tire. I run Continental DWS and it's a comfy and quiet ride. Also if you're going after a flush fitment, your gonna have to roll your fenders. I'm stock height on my 19's and I get a little rub in reverse and with big dips on the highway with passengers
Old Mar 23, 2020 | 05:30 AM
  #2126
KidWeaBoo's Avatar
KidWeaBoo
Thanks for the advice! What kind of offset do you recommend? I know that stock is +45, should I go 40 or lower or should I just stick with the stock offset?
Old Mar 23, 2020 | 05:44 AM
  #2127
AspireXVIP's Avatar
AspireXVIP
I want to say you'll be ok with +40 offset, but offset is a tricky thing. On my RWD 08 GS350, I used a +38 offset and didn't have clearance for the calipers. The stock front calipers are pretty big on these cars. My advice to you would be to use a fitment calculator before purchasing any rims. I talked to a friend of mine at the local les schwab and he was able to use a fitment calculator to determine my wheel size options. Fitment industries also have a fitment calculator on their web site, which tells you what the ideal fitments are based on your car.
Old Mar 23, 2020 | 05:56 AM
  #2128
AspireXVIP's Avatar
AspireXVIP
Here's some info on fitment industries site about your size, width, and offset. Offset is dependent on what wheel width you go with so keep that in mind
Old Apr 14, 2020 | 06:57 AM
  #2129
DrScientis's Avatar
DrScientis
(UGH, dumb scrolling thing and i ended up posting to some other thread)
hey guys, first post here. ive been driving my old man's lexus around so much, i decided to treat him to some new wheels and tires. so if anyone is looking for another data point on fitment, here you go.
car is a 2011 gs350 awd
front:
Konig Dekagram 19x8.5 et30
Continental ExtremeContact DWS06 225/45ZR19
Rear
Konig Dekagram 19x9.5 et35
Continental ExtremeContact DWS06 255/40ZR19
no spacers. no rubbing. although i have a set of tanabe df210s that will go on soon. and will report back on rubbing after those.
the lateral fitment is just perfect in my mind: check the pics.
also, these wheels are REALLY lightweight, and dont break the bank. larger tire AND +2 larger wheel, and they still came in 3lbs lighter each than the factory setup.
Old Apr 26, 2020 | 12:04 PM
  #2130
alb3rtito's Avatar
alb3rtito
2011 GS450H
OEM ISF wheels
235 40 19 front
275 35 19 rear
15mm spacer all around
Looking at suspension next
