Gs350 awd pulling to right?!
Old May 19, 2009 | 11:13 PM
DjVolume's Avatar
DjVolume
Exclamation Gs350 awd pulling to right?!
PLEASE HELP I GOT AN 08 GS350 AWD WITH 12K, STARTED PULLING TO THE RIGHT RIGHT AROUND 5K TOOK IT TO DEALER ALLIGMENT IS GOOD, THEY TRIED TO PUT NEW TIRES INSTEAD OF THE ORIGINALS DUNLOPS THEY GOT ME AND ALL SUMMER BRIDGESTONE(THEY SUCK) STILL CANT FIGURE OUT WHAT IT IS BEEN IN TOUCH WITH REGINAL SERVICE MANAGER, SHE CANT HELP, ANYONE ELSE WITH THIS PROBLEM? WAS TOLD BY LEXUS SERVICE MANAGER TO FILL LEMON BUT IM TRYING TO AVOID THAT
Old May 20, 2009 | 02:24 AM
01a4man's Avatar
01a4man
Does it do it all the time or just certain roads? Road Crown will cause most people to think their alignment is off when it really isn't. All roads are designed to crown in the middle so that water drains away from the road surface. If it's only certain roads, then you are probably good. If it's all the time, then there is a problem. The mechanic should be able to offset the alignment to make the car track straight.
Old May 20, 2009 | 08:39 AM
Evel's Avatar
Evel
I had similar drifting/pulling (steering wheel out of sync with wheels) for the 1st yr of ownership too. Regional/District Lexus Mgr had complete suspension system tested...everything was okay. The determined I sold a bad set of Dunlop run flat tires (perhaps the car sat too long at docks or dealer lot & developed "flat spots"). Once new set of tires was installed (June '07), the drifting problem went away. From time to time, I experience the pulling/jerking sensation on high crowned or rough roads in my area, but the alignment has remained true. Sorry you're having so much trouble. Question, are experiencing pulling/drifting while driving (on accelerator) or when braking?
chanho083
Nov 9, 2019 05:43 AM
jonathancl
Feb 25, 2018 12:59 PM
HenryHYee
Apr 14, 2008 06:33 AM
aspec07
Aug 23, 2007 06:27 PM
