Rattle from top of dash on passengers side. - Need some details please........
Old 11-02-07, 11:28 AM
Cut-Throat
Cut-Throat's Avatar
Default Rattle from top of dash on passengers side. - Need some details please........
When the weather got cooler this fall, I thought I had the center console rattle, but it turns out something is clicking on the passenger side of the dash. I determined this, because if you push down on the top of the dash above the glove compartment the noise will stop. This happens when going over the small bumps between concrete pavement slabs.
I would like to know
1.) If there is a specific TSIB for this rattle.
2.) If someone here has had it fixed successfully.
3.) Or if someone has cured this by themselves and how they fixed it.
thanks.
Old 11-02-07, 11:36 AM
vladbph
vladbph's Avatar
Yes, there is NV005-06
File Type: pdf
Old 11-02-07, 11:41 AM
Yang1815
Yang1815's Avatar
Thanks! Mine has this too, waiting for 10k service to get it done at once.
Old 11-02-07, 12:13 PM
Fujifuzz
Fujifuzz's Avatar
with 15,000 miles and 6-10 visits to the dealership, the problems still has not been solved. I've faxed in the TSIB and brought the paperwork and still no lunch. Maybe it's just my luck. It' s starting to make me think about aborting Lexus.
Old 11-02-07, 12:44 PM
Armand
Armand's Avatar
Not a helpful reply but did want to mention the irony of interior noise. That irony being that as they have insulated us from exterior noises over the years, the interior noises are now the ones that stand out and drive us crazy. Noises will always be present in one form or another, a car is made to bend & flex somewhat when necessary so if you apply basic engineering principles you'll understand why you get creeks and pops as you drive. We are just hearing them more because the exterior noise has been dampened so much. Of course this doesn't apply to the obvious rattles and creeks from loose parts (speakers, harnesses, ect).
Old 11-02-07, 01:17 PM
Yang1815
Yang1815's Avatar
Without isolation from exterior noises, we wouldn't have been able to hear the interior noises.
Old 11-02-07, 10:53 PM
2thfixr
2thfixr's Avatar
TSIB doesn't help. Your best bet is to push some dense felt between the glass and the dash to put some compression on the area. Don't worry though, it will go away when the weather warms up.
Old 11-03-07, 08:19 AM
Cut-Throat
Cut-Throat's Avatar
I don't buy this one at all, because my 99 GS300 was quieter than my 07 GS350 - both inside and outside. Lexus cars have gotten cheaper, but still are probably the best on the road.
Old 11-03-07, 08:29 AM
bokmeipai
bokmeipai's Avatar
You are comparing 2 diffrent types of cars. The RX has a softer suspension and smaller wheels and high profile tires vs. GS with sportier suspension & bigger wheels /low profile Run flat tires. Put that into the equation and you get road noise mostly coming from tires.
Old 11-03-07, 08:37 AM
Cut-Throat
Cut-Throat's Avatar
Who said anything about an RX?
Read my post.
Also, I took my run flats off when the car was new and replaced them with the smoothest riding Michelins available.
Old 11-24-08, 04:43 PM
LexV8
LexV8's Avatar
Try the glove compartment fix.
https://www.clublexus.com/forums/sho...t=glove+rattle
m1c
01-30-14 12:12 PM
DB S600
10-22-10 03:50 PM
8UANEW1
02-23-10 09:50 PM
vertcobra9
03-08-07 10:06 AM
Ramirez
05-05-04 09:28 AM
Quick Reply: Rattle from top of dash on passengers side. - Need some details please........
