i hit my 07 gs350 on a metal plated curb turning ... worried
whats up guys it was one night i was a fool i was driving back home from clubbing and on a turn i nibbed a curb no body damage but i ruined the front bearing i took it to lexus and they replaced my cars front wheel bearing and a front axel now after this happend iam paying attention to every tiny thing noise and the cars ride when iam on the freeway i think theres a veryyyyy slight raddeling when i hit the gas when i let go its smooth but only on 80mph 60 mph smooth 90 or 100 smoootthh is there anything i should get checked out again or i shouldnt be worried cars a month old
if anybody has any info please write back to me or hit me up crazyrus18@netscape.net thankss
I had the same problem. I hit the curb in the snow twice and damaged 2 wheel bearings but minor damage to the wheels. The bearings began to make noise almost 4 months later during the spring and made turbine sounds at high speed that you could feel through the steering wheel and pedals. Make sure that the axle is not damaged or the bearing is properly greased because the dealer had to replaced the new bearing one more time due to improper replacement earlier. I have had no problems now for 1 year. If it makes noise or vibration when you hit the pedal and not when you let go the pedal, then there is something with the axle. If its constant noise or vibration coming and going regardless of whether you are accelerating or foot off the pedal, then its the bearing. Hope this help.
Occasionally check to see if the previously damaged front wheel (not the tire) is very hot to the touch after an extended ride. If you are still having bearing problems that wheel will be noticeably hotter than the other front wheel. Of course, any unusual noise or vibration is also a sign of a failing bearing. Also, watch your tires for signs of unusual wear and pulling which are signs of front end misalignment.
0oh so basically ill take it for a half hour spin on the highway and feel each rim to see is if its hotter than the othor right
i dunt belive it would be the bearing because i changed it and the axel right after it happend which was 3 weeks ago plus i dunt belive that i hit the curb way to hard because othor wise i would of damaged the gray door trim panel basically all that happend to it was get scratched very lightley no dents or hard hit
i ran over a very large rock 2 weeks ago and blew a tire. they dealer did an alignment but I still feel a very slight vibration inthe wheel and the pedals at higher speeds. im going to take mine in and have the bearings front and rear checked
DId you get your car fixed after the vibration? I hit a curb at the airport 5 weeks ago with my front right wheel. Afterwards, there was vibration in the steering wheel, so I got that tire rebalanced and all the 4 tires rotated. I did a 4wd alignment since that wheel I hit pushed it out of alignment, but it wasn't a hard kind of hit. But, I still feel a slight vibration through my steering wheel and floor and it comes and goes randomly (no pattern) and depends on what road I am on. The dealer tells me that it may be due to cupping of one of the tire, but I know it might be a bearing or something loose on that wheel since the tire that I hit is now moved to the back of the car and I still get some slight vibration, so it has nothing to do with that rim and tire that I hit.
Did the bearing fix your problem?? I might need to take my car back in and have them inspect everything properly this time.
lexluthr1x
05-24-15 08:11 PM
