tps tire pressure sensor question
so i'm looking for a set of 20's for my new car and i was reading about the tps and i would need four new tps for the each rim is this correct.?.what else would i need to do or is it possible to not install the tps.?
any drawbacks or problems i would have not installing new tps in to my new rims?
thanx
thanx
You don't need new TPS. You could put the existing ones onto the new rims.
If they don't fit, then you could throw them in the spare so the warning light doesn't come on.
That or you could drive and ignore the warning light.
The only drawback I could see is that your Lexus won't be able to warn you when you have a leak.
There some wheels that come ready to accept the TPS and any good wheel shop SHOULD BE familiar with these. Make sure to ask them BEFORE you give them your car if they have experience in doing this swap. The spare tire answer will work but not one that I would be comfortable with. I went with IForged wheels and have had no issues with the TPS in fact it saved me from driving on a leaky wheel.
IE_Dave
IE_Dave
or you can do a search, I think someone made a pressurized container out of PVC tubes and put TPMS in there???
The TPMS does not monitor pressure per se, only the differential between one tire and the other three, if so, just put the sensors in your glove compartment, the system will be fooled into thinking all four tires are in equilibirium, pressure wise, at 0 psi. and the warning light should not show up....
Lerking Newbie here,
I'm in the same boat regarding the TPMS. I want buy 4 new TPMS for my new wheels and keep the OEM set in the garage. Anyone know where I can purchase these for a decent price?
I put 19 on in the spring. I got 4 new tire pressure sensors from Sewell Lexus in Texas, they had the best price at $88 per sensor. I then had them installed on 19 inch, five spoke, HRR Chrome wheels. MAKE SURE WHOEVER MOUNTS THE WHEELS USES THREAD SEALER OR THREAD LOCKER ON THE TPS SENORS.These factory sensor are the threaded value stem type. If you dont use thread locker your tires will air down when you drive. Now you have to pay your Lexus dealer to program the ECM to recognize the new TPS. They charged me $25. When I switch from my summer tires back to "winter" factory tires I press a button found underneath the dash on the passenger side. This switches from one set of TPS to the other and vice versa.
Having the red light on would drive me nuts, thats why I did it the right way.
Thank you
Do you know why the new factory TPS sensors have to be programed? If I decided to remove the TPS from the old wheels and place them on the new ones, would I still have to program the ECM?
because they need to be linked to your car.....
NO
NO
EyeKutr,
Thanks for your response. I'll just take the ones off the OEM wheels and place them on my soon to be 19 or 20's.
I have purchased 4 used OEM Tire pressure sensors for my 06 GS 300, Would need to have the sensors programmed for my car? I placed the sensors in the spare equally spaced apart and followed the reset procedure with no luck. Will the glove compartment option work if the sensors are programmed for my car? Any info would be great.. Thx Mobb...
