Upgrading Mark Levinson, Need Help!
Old 07-05-06, 09:03 AM
S2peed
S2peed's Avatar
Default Upgrading Mark Levinson, Need Help!
Hey guys,
I have the Mark Levinson system and am looking to tweak it a bit and get a higher quality of sound without sacraficing too much.
I am looking to just upgrade the speakers and the subwoofer and add a amplifier. I want to keep everything else factory.
My concern is the factory DTS/Dolby Digital decoder, I am not sure if this is build in on the factory amplifier or is it built on the head unit. I dont want to take the Oem amp out and loose the decoder. I hope everything is built of the head unit that way i can swap out the amp and the speakers.
Also How many speakers are in the Mark Levinson System and what are all their sizes?
Thanks!!!!
Old 07-05-06, 01:38 PM
4TehNguyen
4TehNguyen's Avatar
if the ML in the GS is like the IS, the amp itself has a built in crossover (i think, theres a crossover somewhere), which I dont know if youll get that in an aftermarket amp. Also doing a new amp looks like youll have to run all new wiring if you are up for that/ Theres a guy named cmusic that posts info on 2IS audio he should have a lot of basic information but not sure about GS specific info
Old 07-07-06, 05:20 AM
nardeezy
nardeezy's Avatar
The DTS/dolby digital decoder should be uilt into the head unit. The amplifier should provide only power to the speakers. The amplifier is located on the right of left side of the trunk floor near the tali lights. Check it out. It is very do-able to upgrade the speakers and amplfier on the vehicle. You may need a very good amplfier though (e.g. either 2 amps or a multichannel (5-6 channel) amplifier). In my opinion, I think you should just leave it alone. However, I know how it is to want better sound.
Old 07-09-06, 08:54 PM
DrexLex
DrexLex's Avatar
The Dolby and DTS decoders are in the amplifier, which is located on the right side of the trunk. The head unit has no means to connect 6-ch decoded audio to the amp. The connections are 2-ch analog and S/PDIF for 2-ch PCM or bitstreams. If it did have 6-ch audio, we'd also have full DVD-A capability, but we don't, unfortunately.
natman
06-19-19 09:12 AM
Indulgent
12-28-15 02:31 PM
shawnberry
09-11-08 09:32 AM
S2peed
03-29-07 07:29 PM
Quick Reply: Upgrading Mark Levinson, Need Help!
