Tire Pressure Monitor Fix (pics)
Old 06-15-06, 09:15 AM
Eternity3G
Eternity3G's Avatar
Default Tire Pressure Monitor Fix (pics)
1) Mark the spot where you'd like to open the hole to install the sensor. You want to find a spot with similar curvitures as the stock wheel for best fitment. We are essentially installing a secondary valvestem. (remember you need the entire stem adn sensor unit from factory wheel)
2) Start with a small bit and drill a pilot hole.
3) Use a larger bits to open the hole just enough for the sensor to go through. Or to make life easier, use a uni-bit. I forget the hole/bit size... sorry guys...
4) Attach sensor and stem...
5) Try to position the new stem opposite the "actual" stem for better balance. You won't have to utilise as many weight when balancing the wheel.
6) Here's a view of the sensor from the other side after the tires been mounted...
Old 06-15-06, 11:07 AM
webhed
webhed's Avatar
Awesome, great post. Mods, this should have a sticky.
Old 06-15-06, 11:09 AM
SGT
SGT's Avatar
+1... already in the sticky, https://www.clublexus.com/forums/sho...65#post1955565
Old 06-16-06, 10:55 PM
nardeezy
nardeezy's Avatar
FYI, if you want to avoid the drilling, you can purchase multi-piece custom wheels that already have the hole center drilled. When I purchased my iforged wheels they were pre drilled in the same location.
jeff1rey
ES - 5th Gen (2007-2012)
10-17-19 11:46 AM
GQis350
08-24-12 10:36 PM
ward1016
10-19-07 12:14 PM
AlexusAnja
02-22-07 03:46 PM
Eternity3G
Wheels, Tires & Brakes Forum
06-21-06 08:50 PM
Quick Reply: Tire Pressure Monitor Fix (pics)
