Change NAV destionation while in motion
Old Jun 29, 2006 | 05:47 PM
  #91
knicker's Avatar
knicker
Default this didnt work for me????
[QUOTE=E55_POWER]Here's a try....
Hit MENU button on the right side of screen you should come to this window.
Click on Volume. Once in the Volume MENU, click on top left where the picture of the speaker is
Then Click on bottom left (I know there's nothing there but click on it
Then Click on top left again, the picture of the speaker
Then Click on the bottom left again
It should bring you the SERVICE MENU
Once here, click on OVERRIDE but keep holding it til you here a beep. Once you hear a beep, the OVERRIDE should be highlighted like below.
You MUST do this everytime you start your car. I have confirmed that this works on 2005 LS430 as well. Have not tried any other cars.
Alright so I have an 06 gs3 and I tried this and my Dest button and my map button both didnt do anything until I turned the car off and back on......When I hit the buttons a black screen came up.....there is no issues now but it was weird
Old Jun 29, 2006 | 06:23 PM
  #92
larrs's Avatar
larrs
Once you've highlighted the OVERRIDE button, you have to touch the BACK button on the top right of the screen ... then DEST and MAP will work.
Old Jun 30, 2006 | 02:43 PM
  #93
knicker's Avatar
knicker
DAMN that back button........it works fine, im retarted.
Old Jul 3, 2006 | 02:48 PM
  #94
LoVeMy06IS's Avatar
LoVeMy06IS
Originally Posted by E55_POWER
Here's a try....
HAVE FUN PEOPLE!
you are awesome! The 15 seconds is better than cutting up my wires! lol..
Old Jul 3, 2006 | 11:05 PM
  #95
Raptor.1's Avatar
Raptor.1
The cutting of the wires is only needed if you want to watch DVDs while in motion. Even after the wire cutting you still have to go through this proceedure to do nav input while in motion.
Old Jul 3, 2006 | 11:55 PM
  #96
PoppFlyy's Avatar
PoppFlyy
Default Navi lock-up
Thanks for posting the menu steps Knicker.
I just wanted to add on thing to this thread. My guy at my service dept. told me about this override, and he said it's buggy. The computer can lock up, and if it does, the whole navi comp has to be replaced, and it won't be covered by the warranty.
Good luck guys...
Old Jul 5, 2006 | 08:17 AM
  #97
PeteV's Avatar
PeteV
Good luck guys...
...and we all know how reliable information from the dealer can be...
Old Jul 5, 2006 | 10:03 PM
  #98
anwar1337's Avatar
anwar1337
GUYS Listen, what ever you do, dont go to the GPS section and pick a different "US-##" Tab, it will reboot the NAV ECU and will say "Please insert Correct Disk" thats what I did to our lexus and after 8 months we finally took it to Lexus and tomorrow they are installing a brand new nav ECU . So yeah being curious has its lessons?
  #99
anwar1337's Avatar
anwar1337
It might be the Version tab, excuse me as I dont remember since the last time i saw it was like 8 months ago :P
Old Jul 7, 2006 | 10:28 AM
  #100
clubfoot's Avatar
clubfoot
Must be the version tab, or you ejected the NAV DVD, as I just came back from F1 in Indi and switched the US# a couple times while on my trip from Canada, no problems.
Old Jul 21, 2006 | 11:13 PM
  #101
Sexi_Lexi's Avatar
Sexi_Lexi
I previously couldn't get it to work on my IS350 but now I can so it does indeed work on the 2IS.
Old Mar 8, 2007 | 07:30 AM
  #102
BlueBerry3's Avatar
BlueBerry3
Hello,
Can you help me with the navigation "Override" trick ? You said it worked with your IS 350. I can make it work with mine.
Do you know the version of your NAV system ? Is it v4 or v5 ? Mine is v5, and it doesn't work.
Did you do anything special to enter that "Override" menu ?
Thank you in advance,
Blue.
Old Mar 14, 2007 | 01:50 PM
  #103
OC 335d's Avatar
OC 335d
It doesn't work on our IS250 either. MY2007.
Old Mar 24, 2007 | 10:50 AM
  #104
ecalhoun's Avatar
ecalhoun
It doesn't work with my 2007 IS350 either. It looks like Lexus finally changed the way to access the override button, now that the method was more or less common knowledge.
Anyone know how to access it on a gen5 model?
Old Mar 28, 2007 | 07:58 PM
  #105
vuiskool's Avatar
vuiskool
^ that is something i wanna know too. SHARE THE WEALTH!!!
