07 Lexus GS350
Old May 29, 2025 | 06:37 PM
Ace1984's Avatar
Ace1984
Default 07 Lexus GS350
Hi
I have a slight vibration when turning 20 degrees to the left only it goes away if i keep turning it does it at a stop or driving. Its more noticeable at a stop. Any suggestions what could it be?
Old May 29, 2025 | 09:57 PM
Oro's Avatar
Oro
- Lift the front of the car. Jack stands under the front subframe on each side, do not do this on just the lift jack alone.
- Grab the wheel and rock vigorously in the 3-9 o’clock directions
- repeat 6-12 direction.
evaluate for any looseness; it should feel rock solid. If you note it in different dimensions, you can evaluate it as bearing, ball joints, or tie rod issues.
When you are turning left, you load the right side more heavily. You need to check both sides.
Ace1984
May 16, 2025 11:16 AM
mqas
Suspension
May 4, 2025 10:52 AM
Iparkcars
Apr 29, 2019 09:59 AM
mshmsh
Nov 15, 2013 05:22 PM
gaspowered
Aug 28, 2006 09:15 PM
