Tire widths different in front on AWD?
Old May 5, 2025 | 06:51 AM
Mxandy35i's Avatar
Mxandy35i
Default Tire widths different in front on AWD?
Would it be okay to have 20 inch (255 vs 235) wider tires in the rear but same exact side profile and size?
Old May 5, 2025 | 02:25 PM
Oro's Avatar
Oro
Since the center differential is full-time planetary, and not on-demand slip dependent, it *might* be OK.** You can use tiresize.com to compare and calculate how much it messes up your instrumentation. Tire rotation is now ineffective so you will have higher maintenance and costs because of that. Doing this will definitely destroy many awd systems; I’m not positive here.
** - There are wet clutches that vary the ratio from 69:31 to 50:50 based on detected slip. The new f/r ratio differences might be activating these continuously and wear them out (expensive problem if so). I am not sure so you will have to find someone very knowledgeable about the i-four system to verify. Here is a technical explanation of the system so you can see how it works and what I am talking about:
https://toyota-club.net/files/faq/11..._ifour_eng.htm
DS03
Jan 5, 2023 06:28 AM
Anfanger
Jun 13, 2021 06:20 AM
3GS
Aug 4, 2015 09:42 PM
midnite23
Wheels, Tires & Brakes Forum
Apr 27, 2009 03:52 PM
tsavo
Apr 19, 2009 02:48 PM
