Code p2238 and p0300 only under hard acceleration
Old Jun 17, 2024 | 07:20 PM
kamontj's Avatar
kamontj
2nd gear
Default Code p2238 and p0300 only under hard acceleration
P2238 and p0300 only under hard acceleration. When i restart the car its gone. And drives normal. It also hesitates like hell
Old Jun 18, 2024 | 02:06 AM
ibidu1's Avatar
ibidu1
When was the last time you replace your sparkplugs, and were they oem or original denso plugs and not fake plugs? If not recently I would check or replace all the plugs with iridum denso. What about the maf sensor, have you cleaned it? Also throttle body have you cleaned that? I checked the air filter, the tube from the air filter to the throttle body, make sure theres no air leaks in between
Fillex
Feb 26, 2024 05:39 AM
Seanmurphy
Dec 12, 2022 04:23 PM
SCORP69
IS F (2008-2014)
Mar 7, 2019 12:04 PM
