2010 GS350 AWD crank position sensor
Old Jun 15, 2024 | 11:04 AM
Jitterbug's Avatar
Jitterbug
Default Battery changed
I got my battery exchanged for free. I guess at this point I’ll give it a few more tests. My car wasn’t sitting. How do you check for a parasitic fuse when the wires on a multimeter are so short?
Old Jun 22, 2024 | 04:28 PM
Jitterbug's Avatar
Jitterbug
Default Thank you all
I just want to thank everyone for the help. It turns out that I just had a bad battery even though it was only a year old. I gave it a couple of days after changing it before replying and when the car is running it’s showing 13V, so I’m glad I didn’t jump into changing the CPS. Thanks again everyone!
Old Jun 22, 2024 | 10:46 PM
ibidu1's Avatar
ibidu1
awesome news, hopefully its just that. I would still go through the electronics to make sure what is the source thats killing the battery. Repeated drains, inconsistent charging, or even different spikes in temperature can kill batteries.
Old Aug 16, 2025 | 10:04 PM
Bserch's Avatar
Bserch
Default Crankshaft
I got the part from NAPA. It clicks a lot but I don’t know what else to test. I’m kind of a rookie, but I am also really broke right now. What else might it be? I can borrow a volt meter but I don’t know what to test.
Hi 👋 im having the same problem but I know we're its located on my engine its not on top its on the side of your engine were the crank pulley its the driver side my car is starting fine and drives great but im getting a crankshaft code it goes off and comes back it could be trash in side or the connector don't buy after market parts they want work good luck
Old Aug 17, 2025 | 06:50 AM
Jitterbug's Avatar
Jitterbug
I haven’t had any problems since replacing the battery.
Old Jan 11, 2026 | 11:59 AM
inked05's Avatar
inked05
I just replaced my valve cover gaskets on bank 1 and 2 now I'm getting a cam sensor code , its the exact same one that's in the picture at the top of the valve cover on bank 1. Before doing the job, I did not have a code. I disconnected the battery before the job , I reconnected it and cleared the code, but it keeps coming back, I removed the sensor and cleaned it and make sure all connections were clean and good, any solutions?
Old Jan 11, 2026 | 07:24 PM
skur's Avatar
skur
swap the camshaft sensor with the one on the other side that has a vertical connector. the part numbers are the same, i'm pretty sure when it comes to our camshaft sensors the only difference is if the connector is vertical or sideways.
Old Jan 12, 2026 | 11:35 AM
inked05's Avatar
inked05
Default Cam positioning sensor
Thank you for your help. I found a problem when I changed my valve cover gaskets I missed the one located on Bank one passenger side in the back closest to the firewall it was disconnected. I reconnected it then reset the computer no more codes. 👍🏽
