2007 GS350 Rear Subframe Interchangeability
You should address your concerns in Normal Threads on GS forum
https://www.clublexus.com/forums/gs-...2006-2011-153/
2006 GS 300 is the same as 2006-2013 IS 250 RWD, 2009-2013 IS 250 AWD, and 2010-2015 IS250 C (205 mm Differential)
2006-2007 GS 430, 2006-2011 GS 350, and 2007-2011 GS 460 is the same as 2006-2013 IS 350, 2008-2014 IS F, and 2010-2015 IS 350C (208 mm Differential)
Bushing stiffness varies between models, but the subframe does not.
