Looking for easy podcast solution
Old Nov 7, 2023 | 06:04 PM
danmurphymn's Avatar
danmurphymn
Default Looking for easy podcast solution
Hey all, I'm buying my first Lexus on Thursday! A 2006 GS 430. I'm so excited!
From MN, I'll be buying it from CA to find a rust free option.
I have tons of stuff to figure out before then so I don't want to spend a bunch of time looking up how to setup bluetooth.
What is the quickest, easiest way so I can listen to my podcasts & music on the road trip back home? Wired is perfectly fine!
Amazon links preferred!
Old Nov 8, 2023 | 07:54 AM
jmonteiro's Avatar
jmonteiro
The easiest would be to use one of those cassette tapes with a wire to connect with your phone using a 3.5mm. What I use in my 07 GS350 is a USA Spec device called the BT45-TOY. It connects to the back of the headunit and uses an accessory port. Not sure if that would work with your model but whatever you choose for a permanent solution will require more work to hook up. https://www.usaspec.com/Lexus-GS350-...-bt45-toy.aspx
Looks like the price has gone up significantly for the unit I'm talking about but you can shop around like on Amazon or Ebay.
caverman
Jul 29, 2017 03:18 PM
twzou999
Jan 27, 2017 07:12 PM
TIC
Apr 20, 2015 09:18 PM
LenniePaz
Sep 10, 2012 07:12 AM
carlmock
Oct 24, 2006 06:59 PM
