Whats happening here??
Old Oct 22, 2022 | 01:34 PM
QLex300's Avatar
QLex300
Default Whats happening here??
Seen this today, whats happening here? Looks like the hose that connects to the motor is sucked in..
Car is not running hot according to temp guage..
Appreciate any advice..
Please advise...
Old Oct 22, 2022 | 01:56 PM
Naidni45's Avatar
Naidni45
2nd gear
Default rad cap?
check to be sure your rad. vent tube is not plugged with sludge. clean the overflow tank and be sure the line from tank to rad. is clear.
overflow tube is usually located on the filler neck of the radiator, below the rad cap.
BE SURE ENGINE IS COOL PRIOR TO REMOVING RAD CAP!! I don't want you to get a scald on your hand.
if the hose does not return to normal shape when you release the rad cap pressure, the hose is worn and should be replaced beofere it fails under pressure.
Old Oct 22, 2022 | 06:35 PM
DundukovEM's Avatar
DundukovEM
The radiator cap itself may also be faulty. Basically, it does not open the vacuum vent valve in engine cooling conditions and your cooling system creates a vacuum that compresses the hose.
Old Oct 24, 2022 | 03:56 AM
QLex300's Avatar
QLex300
Thanks
I replaced the cap, hose and cleaned out the overfill.
Thanks
O. L. T.
May 13, 2020 11:48 AM
Gojirra99
Nov 20, 2006 07:16 AM
3GSLEX
GS - 1st Gen (1993-1997)
Oct 6, 2003 04:45 PM
