Lexus gs300 error code P0351
Old Oct 12, 2022 | 11:27 PM
Allmoon's Avatar
Allmoon
1st Gear
Default Lexus gs300 error code P0351
Hi all, I just replaced the sparks and gasket cover with lexus gs300 2004. Now after replaced these the car turn for 3sec. Then engine turn off by its self I checked by OBD and get error P0351Ignition Coil 'A' or 1 Primary/Secondary Circuit Conditions. I changed the all ignition Coil and still the engine does not working more then 3 Seconds. Before that the car working fine, Please need help with that Thank you
Old Oct 13, 2022 | 08:21 AM
Raven01750's Avatar
Raven01750
Deleted due to ignorance! 🤣
Paul
Old Oct 21, 2022 | 06:50 PM
lastguy's Avatar
lastguy
It would be the front one. You get to replace all control wires casing(2pin) with genuine parts, check any peeling wire insulation.
zakkgs300
Aug 2, 2019 01:32 PM
kevinhuule
May 14, 2018 08:05 PM
lildorsey1
May 13, 2015 01:47 PM
