Need help with transmission question
My transmission gave out on my 2001 GS 430, I found a good used one from a SC 430, it says it will fit on my car but is there any difference with the gearing ratios? Will it be the same? Or should I get it only from another GS430?
Even tho they are both the same A650E transmissions
on a side note, transmissions rarely fail on the 2GS. How many miles do you have and was the fluid ever changed? Curious why it failed
